O2 Sensor Question
Old Mar 16, 2004 | 12:37 PM
97WS6SCharged's Avatar
O2 Sensor Question
Ok, I need to replace my O2 sensors, one is bad, and the wiring for the other sensor kinda melted against the exhaust. I'm probably going to order from GM Parts Direct (good price), but I need to know where to get a replacement plug and how I should go about wiring it in. Any ideas?
Thanks.
Old Mar 16, 2004 | 05:44 PM
TTT... Anyone?
Old Mar 16, 2004 | 06:29 PM
Compstall's Avatar
Well, you DO get about a foot of wiring with a new O2 sensor. It comes with a harness and connector built in to it. If the wiring beyond that is melted, you could probably splice in some new wire and put some fire sleeving on it for a fix.
Old Mar 16, 2004 | 10:17 PM
Yeah, the plug in the plastic factory harness melted. I was wondering if anyone knew where to get a new plug.
Old Mar 16, 2004 | 10:47 PM
ledfootz28's Avatar
hmm i think ur in the same situation i was in.dunno what plug ur talkin bout but on my pass side o2 both the harness from the car and the o2 harness were melted.i bought one from jason cromer,cut off the harness,cut off the harness from the car and spliced and crimped them together,then heat sleaved it.
however after i did this i immediatly throw an SES after 10 seconds after startup.i either ****ed up the resistance(very important)or crossed two wires.i suggest u solder the wires with a solder gun.that way you will not mess up the resistance.thats what im gonna do soon and check to see if i crossed two of the wires.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
