o2 question
Old Feb 25, 2003 | 11:17 PM
cals400ex's Avatar
o2 question
i believe the lt1's came with 3-wire o2's. can i use a lt1 o2 in a 3rd generation? if not, i am looking for a 3-wire ac delco for a 3rd gen and i don't know a part #. help would be great
Old Feb 26, 2003 | 12:27 AM
Re: o2 question
The 93 LT1's had single-wire O2 sensors. The 94 and newer models have 4-wire sensors. All the 3rd Gens I have seen use single-wire sensors. I doubt that you could use a 4-wire LT1 sensor, since the LT1 sensor connects 2 wires to the PCM, both a high and low reference signal.
Old Feb 26, 2003 | 04:21 PM
cals400ex's Avatar
so it is not possible to hook a 3-wire o2 on? i don't really know the benefit of doing a 3-wire set up over the 1-wire set up. can someone try to explain this. thanks
Old Feb 26, 2003 | 11:22 PM
The "extra" wires are for "heaters". These use a +12V power supply to insure the O2 sensor stay hot enough to operate. If they get to cool (below 600degF) they won't work. With stock O2 sensor locations, you will be OK with single-wire sensors, but if you have to move the sensors away from the engine... e.g. with long tube headers.... you need heated sensors.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
