NSA or Self Aligning RR's
Old Sep 9, 2006 | 12:42 PM
WonQuickZ28's Avatar
Is there an advantage to going with NSA roller rockers, guideplates, and hardened pushrods VS. just a set of Self Aligning roller rockers?
I plan on changing the springs and all that fun stuff to LT4 stuff, but I saw a few suggestions via the board that hint towards the NSA setup. Thanks in advance.
Old Sep 9, 2006 | 01:11 PM
Another Red Z's Avatar
Re: NSA or Self Aligning RR's
IMO if you are using the stock cam stick with the SA rockers.It will be cheaper and easier to do.If you are going with a cam with lots of lift go with the NSA as it will be more stable at higher RPMs.Going NSA can get expensive quick if buying everything new.
Old Sep 10, 2006 | 06:08 PM
SStrokerAce's Avatar
BTW IF you want to upgrade later on a 7/16 stud, GMPP guideplates and NSA Pro Mags are the way to go, if not use something like the Hot Cam rockers.
Bret
Nutty's96
Dec 21, 2015 06:25 AM
karpetcm
Sep 15, 2015 11:07 AM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
2QUIK6
Jul 15, 2015 07:46 PM
