Not to loud catback
Old Oct 25, 2005 | 10:20 AM
  #46
JakeRobb's Avatar
Super Moderator
Re: Not to loud catback
Hey, like I said, I don't know valvetrains all that well. Maybe the stock rockers have tons of friction, and maybe you can get the 10-15hp you were hoping for. You should probably start a new thread in the LT1 engine forum and ask for yourself.
Regardless, aftermarket rockers are probably stronger, and maybe lighter (like I said, I don't know). When you're going to high-horsepower stuff like that, sometimes you just have to put in some stronger pieces to support the power you're making. It's kinda like dropping $2000 on a 12-bolt, or a hundred on a set of cro-moly pushrods. It won't do a thing for your times, but it's definitely worth the money.
Old Oct 25, 2005 | 12:26 PM
  #47
HardcoreRM125's Avatar
I heard that the 1.7's they make are supposed to be pretty nice quality too. Just make sure you get a set of GM guideplates for it. Regular SBC plates wont fit it properly, and switching from 1.5 to 1.7's you definatly will need new valve springs, so get a valve spring compressor. Get the one made for an LT1 though, it makes the job easier and the tool is like 2o or 30 $ ???
Old Oct 25, 2005 | 01:31 PM
  #48
race24x's Avatar
I am kind of hoping when I get that close I will be able to borrow one from someone on the board or buy one used. 30 bucks isnt that bad I thought they where more. I did get the LT4 springs locks retainers etc so I should be allset I am getting the GM guide plates but I am going to replace the studs at that tiem you might as well cause you have to unscrew them to put in the plates.
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
SSCAMARO1659
Aug 30, 2015 08:45 AM
Nickster 7
Aug 27, 2015 10:12 PM
