Not holding fuel pressure after shut down
Old Feb 15, 2008 | 08:04 AM
jchevy's Avatar
When I turn off my car I lose fuel pressure very quickly, within a minute the gauge is reading nothing. Should it be holding the fuel pressure for a while?
I just installed an aermotive Boost sensitive FPR.
Old Feb 15, 2008 | 09:06 AM
ss.slp.ls1's Avatar
Do you know for sure that it was holding pressure before the install? It's a pain, but you could swap back in the stocker and see if it holds pressure. When did you install the walbro 340? I don't know if pressure has to hold over night, but it should definitely not be zero after a minute.
Old Feb 15, 2008 | 09:10 AM
jchevy's Avatar
The fuel pump has been in for a while, I did just had to take it out though and clean off the screen, it was plugged up with crap from the sock that was on it.
The FPR is new and the injectors are new.
Is there a check valve inside the pump, I wonder if some of the stuff made it past the screen and possibly messed up the pump?
Old Feb 15, 2008 | 09:24 AM
2000GTP's Avatar
Yes, it is not uncommon for the check valves in the fuel pumps to act up and bleed down the fuel pressure.
Old Feb 15, 2008 | 09:26 AM
a walker's Avatar
Yes, there's a check valve in the pump, and that sounds like your problem.
Old Feb 15, 2008 | 09:30 AM
KENS80V's Avatar
This is normal for the Aeromotive AFPRs. The rep from Aeromotive mentioned this in a previous discussion when I did a search on the subject a while back.
Old Feb 15, 2008 | 10:43 AM
jchevy's Avatar
I was wondering about this. Anyone else heard this?
Old Feb 15, 2008 | 11:09 AM
Not all pressure regulators hold the system under pressure at shutdown. Some, particularly those use in high pressure systems will release the pressure on shutdown, to remove the pressure from the injectors. I have a Weldon AFPR that works that way. When I go to start the engine, I turn the key to on to prime the pump(s) and try to start it exactly as the pump shuts off.
I do not know the specifics of the Aeromotive boost referenced AFPR. Why not ask Aeromotive directly?
Old Feb 15, 2008 | 12:56 PM
Big Lebowski's Avatar
Some pumps will hol pressure. Most factory style pumps have a spuc for it. I don't know what the spec is for the camaro but there is a thime it should hold pressure for and not drop below a certin psi. I also run a high pressure weldon pump and it does not hold pressure on shutdown.
Old Feb 15, 2008 | 03:28 PM
klrz28's Avatar
id say its the fuel pump.. put a walboro in and be done with it never have a problem again
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
