Probs!! IAC Connector and Harness??
Old Feb 11, 2008 | 11:03 PM
BlazinREDZ28's Avatar
Ok, found a problem with the wiring to the IAC connector today. Insulation is damaged by heat, and the bare wires are making contact with each other. Now, where do I find a good one? Tried parts stores local, no luck. Is there a way to fix this? We are having erratic idle probs, IAC counts in 140 range, and the car is running RICH. The IAC connector seems ok, it's the wires that are a prob. Advise, help, number where I can get it?? Anything? Thanks!
Old Feb 11, 2008 | 11:16 PM
Its a low voltage circuit. Carefully tape the wires up with common electrical tape, until you can find a replacement pigtail.
Old Feb 11, 2008 | 11:23 PM
Any ideas on where to find another pigtail? Will I need to soulder the wires and shrink wrap them? And as always Injuneer thanks for the great advice.
Old Feb 11, 2008 | 11:31 PM
http://www.eficonnection.com/eficonn..._pigtails.aspx
Solder and heatshrink is a good idea.
Old Feb 11, 2008 | 11:50 PM
Thanks both of you. You are the greatest.
Old Feb 15, 2008 | 03:49 PM
Big Lebowski's Avatar
The local GM dealer will have or be able to get those. It would be cheaper to get them online.
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
Double aught
Oct 2, 2015 11:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
Thirim
Jul 30, 2015 01:29 PM
