no start, good spark and injecter pulse
the aftermarket security system was not connected to any ignition wires. Only the power windows, door locks and rear hatch release.
Ok, so we've painfully established that the car is not wired backwards. It's starts in the correct direction but rolls backwards when the key is released. Does it do this when the car is warm or cold? Does it do it when you release the key immediately to the off position?
It does it immediately when the key is released from the 'start' position to the 'on' position.
Let's forget about the "running backwards" thing for the moment. Suppose voltage is dropping out to something like the PCM when the key is in the "crank" position but the voltage is there in the "run" position. Might explain why the engine starts when pushed.
However it doesn't explain why if you did like I suggested and left the key on and externally jumped the starter, it didn't start.....Unless you did it incorrectly.
Why don't you look for voltage dropping out to the PCM while cranking????
Which plug and wire is the battery voltage feed for the ECM? The Haynes manual doesn`t give pin locations.
You say it runs fine when push started, but how fine? Will it buck, jerk, or backfire if you get on the throttle? If so, then I would almost bet the timing has jumped a tooth. A few people have mentioned it already, why haven't you pulled the timing cover off and check?
A valid point regarding the timing chain however you don't have to pull anything other than a valve cover and a plug to tell if it's off.
Use a wooden dowel or pencil in the cylinder to follow the piston while observing valve movement. Also, move the crank back and forth while the valves are moving to see if there is any slack in the chain by observing delay in the valve movement.
However, I have given some thought to your problem and I don't believe it's voltage dropping out to the PCM. Your "correct" purple wire test with the key on would have proven that. Although at this point it would still be a good idea to check the 4 voltage connections at the PCM.
I too would like to know how it runs when it is started by pushing it. Are there any dead cylinders? I think you should test all of them to see if any are not firing. But you have to do it while the engine is running. It is this that I think prevents you from starting with the key.
when you push start it it runs fine, no misses or bucking, not at all like the chain has jumped. That`s why I haven`t taken the timing cover off.
"It is this that I think prevents you from starting with the key."
It is what?? cylinders not firing?? It hits on all 8 when you push it.
The positive cable is about the only thing that is left. I suppose if the voltage is dropping right at the cable at the battery, that may cause it. I may throw one on here today if I get a chance.
Here's a stretch...
If the starter engages it cranks fine. When the key is released, the engine turns backwards. What if the starter drive gear isn't releasing? Then it would drag on the ring gear.
When the key is released and if the drive gear is engaged, then may armature would generate a field in a reverse flow and backfeed power. Windings don't care which way they turn, they will generate electricity. Then, if the armature is backfeeding power through the starter, it reverses polarity and causes the engine to reverse direction via electronics.
Testing a starter on the floor is one thing, testing it under load is another. Try a different starter or have it load tested (if Autozone, make sure they test your starter under flywheel resistance/load... not free spin).
Since it runs fine when you pop start the clutch and doesn't run fine when you crank via key, then the issue is likely the starter circuit (electronics/mechanical).
If he's starting the car, then he's engaging the pinion of the drive gear. If the drive gear is binding into the flywheel, then perhaps the drive gear is not release from the flywheel. If it doesn't release, then it will spin the armature and perhaps generate an electric field. Then the electric field would back feed.
Again, this thread has gone on and on. I've stated that I'm stretching on this one. He hasn't swapped the starter motor.
If the wires were crossed, then it wouldn't run fine when he bump-started the engine.
