New Opti installed - need to test
Old Sep 14, 2019 | 06:36 PM
  #46
Re: New Opti installed - need to test
I’ll download the file in the morning when I can access my PC.
Old Sep 15, 2019 | 12:38 PM
  #47
Great job on the fuel pump hatch. Make a solid cover, use body sealer all the way around, use a lot of sheet metal screws to hold it tight. In a roll over, you don't want fuel seeping into the interior.
I assume that the fuel pump was what solved the problem.
Try and track down the source of DTC 11. It's a cut wire or a burned out bulb. That's the only code, but lack of the SES light will delay the discovery of a new problem that turns on the SES light to alert you.
Downloaded the data, set it up in the format I like. Quick look shows both fans running, even though coolant temp is only 185-deg. Fan switch? With just the quick review, everything else looks very good, at idle. Nothing jumps out as a problem. I will spend a bit more time to make sure.
Old Sep 15, 2019 | 03:06 PM
  #48
chevykid's Avatar
the car sat for 2.5 years and when i started it a lot of dash lights not working including SES, also my wipers were stuck in park mode so they would pause straight up and down and swipe off the windshield, but i fixed that. the dash lights are next on my list after i get back on the road. still need to make the gas pump cover, i was cutting a template on my laser last night. I wish it was one that would cut metal.
Thanks again Fred
Old Sep 17, 2019 | 01:24 AM
  #49
chevykid's Avatar
like i said a lot of lights not working in my instrument panel, i took it off tested all the bulbs and they were all good, so i cleaned all the corroded contacts and got them all working but now the brake light is on, does this show up in the computer log?
Thanks!
Old Sep 17, 2019 | 09:03 AM
  #50
Scan9495 will read the ABS computer (EBCM) on cars WITHOUT traction control. You have to select that system to scan it. There should be a tab for it. Will also read SIR (airbag) system.
Old Sep 17, 2019 | 12:04 PM
  #51
chevykid's Avatar
i think this has traction control, because i one time spun the tires in the rain and i remember the traction light came on, also the holes for the "abs inop" & "skip shift" don't have sockets for bulbs.
so is there a way to turn the brake light off without pulling the bulb? (this would be for a temporary time)
Old Sep 17, 2019 | 12:25 PM
  #52
Does the service parts label have RPO “NW9” on it? Is there a black device sitting on top of the driver side valve cover, with the throttle cables attached and a silver servo motor? Both those would indicate traction control (ASR).
I think it should have an ABS INOP bulb whether it has traction control or not. No SKIP SHIFT bulb on a car with auto trans.
The “BRAKE” light comes on for two reasons - 1) when the e-brake handle is pulled up; 2) when the differential pressure switch on the side of the ABS motor block sense a significant difference in pressure between the front and rear hydraulic circuits. The differential pressure switch connects to the EBCM computer (EBTCM with ABS + ASR).
Old Sep 17, 2019 | 05:33 PM
  #53
chevykid's Avatar
No RPO “NW9” on it
Old Sep 30, 2019 | 02:30 AM
  #54
chevykid's Avatar
Fred can you look at this scan:
http://vcs-llc.net/9495scan/DLOG-trans-2019Sep29.csv
I started from cold and did a drive in o-drive on a small trip. normally i drive the car doing manual shifting. but for this scan i let the car shift its self.
thanks for your help.
PS i don't know why when i first got it running the fans would start running a minute after start it cold, but for some unknown reason after i fixed the dash lights, it fixed its self and is working normally.
Old Sep 30, 2019 | 09:53 AM
  #55
What am I looking for in the log - is there a specific problem?
I'm not all that familiar with the auto trans.
Old Sep 30, 2019 | 12:38 PM
  #56
chevykid's Avatar
just anything that doesn't look right, it sat for about 3 years, the factory fuel pump when out, i just went through the opti. for years i always thought it was running rich, but my auto guy i had at the time said emissions are good. i had to clean up all the corrosion on the dash lights and fuses in the fuse box thats when i had the dtc 11.
it seems to be running better than it has in years, i can now red line it, where as before it would cutout and spudder.
just a look at how well the engine is running and fuel system.
Thanks again!
Old Sep 30, 2019 | 04:34 PM
  #57
The log you posted is for the TRANSMISSION, not the engine. I do not know enough about the 4L60E to comment. Never owned one, never worked on one, and I think this is the first time I have seen a Scan9495 log for it.
Old Sep 30, 2019 | 04:55 PM
  #58
chevykid's Avatar
i thought it was the engine at least that is what i saw on the screen, was that whole trip lost?
Old Sep 30, 2019 | 05:03 PM
  #59
The name of the file has the word "trans" in it.... it is just a trans log. There is only on tab in the file, and its is all trans data.
Old Sep 30, 2019 | 08:40 PM
  #60
chevykid's Avatar
i found it here it is:
http://vcs-llc.net/9495scan/DLOG-Save-2019Sep29.csv
Thanks!!!
