New Lsx pcm conversion
Old Nov 1, 2015 | 09:59 AM
David94TA's Avatar
Have you guys seen this?
TORQHEAD LTD - HOME
Old Nov 1, 2015 | 10:54 AM
Re: New Lsx pcm conversion
Looks like the EFIConnection 24X conversion, with an improved setup on the crank and cam position sensors.
Interesting.
Old Nov 1, 2015 | 08:17 PM
Good to see people still thinking about our gen of the LT1. Looks like a bit more plug and play system that might be appealing to more people.
Old Nov 3, 2015 | 05:17 PM
tanmanski's Avatar
This got my attention!
> Reliable. No high-tension spark components to fail. Enjoy the benefits of Coil-on-Plug ignition!!
Dang, missed my chance to be a tester! (I'm not going back there and taking it apart again now!)
Anyone know what price they're planning? I might be interested in it for the 389 rebuild
Old Nov 3, 2015 | 09:24 PM
Prices are listed on the site.
Old Nov 4, 2015 | 08:30 AM
IMHO the 24X system (or this system) is overkill for a normally aspirated (7,000 RPM max) setup. If you want to get rid of the high voltage in the Opti (using only the extremely accurate cam position sensor) and use the LS1 coils in direct fire, the Bailey Engineering LTCC is a lot simpler.
Bailey LTCC setup
I've been using only the optical cam sensor in the Opti as input to an aftermarket ECU for 15 years with no problems. The engine has exceeded it's 7,400 RPM redline on a couple of occasions, and the Opti is still intact. A friend of mine used the same system on a S/C 383 LT1 that was making 1,125HP at the flywheel, and turning close to 8,000 RPM.
And we used aftermarket ECU's only because of the power adders (my nitrous, his 20+PSI S/C) and the simplicity of tuning the aftermarket ECU.
Black_Z
Oct 18, 2015 10:48 PM
fift5
11
Oct 1, 2015 10:31 AM
Grover
Sep 8, 2002 11:36 PM
LVZ2881
Sep 2, 2002 12:35 PM
96z
11
Aug 28, 2002 09:05 AM
