New Jet Hot LT Photographic Install Guide!
Old Mar 30, 2004 | 11:03 PM
  #46
mehoffz24's Avatar
i dont have the #1 tube welded and i dont have a problem at all. but i think if you weld it i suppose you would have a problem with the coating.
Old Mar 31, 2004 | 09:01 AM
  #47
pntballty's Avatar
I put some Walkers sealer on mine before I inserted it. You can get it from Oreilly's for a few bucks. Havent had any problems. Tyler
Old Mar 31, 2004 | 02:37 PM
  #48
LWillmann's Avatar
Originally posted by mehoffz24
doesnt anyone have a problem with the ABS wire and white connector on the pass side. it uses one of the push clips into the inner fender. mine is right next to the primary and is about to burn it, i will be moving it tomorrow. i didnt have a problem with the driver side one bit just the pass side. plug access is much nicer with these instead of the edelbrocks
I haven't had any problems, but one thing I did was to pull a little more of the wire into the wheel well to ensure that it was as far away as possible from the header.
If it's that close, you might want to check your motor mounts.
Nov 18, 2023 07:21 PM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
LT4Ryan
Jul 29, 2002 08:38 PM
