New Jet Hot LT Photographic Install Guide!
Originally posted by mehoffz24
doesnt anyone have a problem with the ABS wire and white connector on the pass side. it uses one of the push clips into the inner fender. mine is right next to the primary and is about to burn it, i will be moving it tomorrow. i didnt have a problem with the driver side one bit just the pass side. plug access is much nicer with these instead of the edelbrocks
If it's that close, you might want to check your motor mounts.
