new engine running rough PLEASE HELP!!!
Old Apr 18, 2010 | 03:30 PM
rustytrumpeteer's Avatar
New to the forum, but I'm in desperate need of help. I just replaced the motor in my 1994 z28 ( the engine ran fine before but developed a rod knock). after replacing the engine, the car will only start with the throttle at half open, and when it does start, I can feel the iac searching for a spot where it will idle, but it wont idle. I have to vary the angle of the throttle in order to keep it running. makes me think its running rich (dont know why), or not getting proper spark (checked every cylinder and its fine. the only things after market are my flowmaster exhaust and high volume fuel pump (i got plans). any input would be appreciated.
Old Apr 18, 2010 | 04:14 PM
bubba4's Avatar
Have you checked for vacuum leaks. LF
Old Apr 18, 2010 | 05:21 PM
95Blackhawk's Avatar
I highly suggest if you are going to be replacing engines and doing additional mods, you must get datalogging capability. If you had this, you would know almost immediately what the problem is.
However, saying that, I think vac leak also.
Old Apr 18, 2010 | 05:32 PM
Have you checked the fuel pressure?
Old Apr 19, 2010 | 08:11 AM
double checked all of the vacuum fittings and i rtved the hell out of it when i was putting the intake on. havent checked fuel pressure. could i have blown the regulator? Ive adjusted rockers and replaced plugs and wires. no change. today Im buying a fuel pressure guage, checking that and compression. what would I need for datalogging?
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
cmdeshon
Dec 12, 2014 10:51 PM
Scottylt1
Dec 4, 2014 12:31 PM
Lions3
Apr 11, 2003 10:55 AM
