need some opinons
Old Feb 6, 2008 | 01:42 PM
cjuvinall2008's Avatar
need some opinons
k guys, looking to build a 355 and i came across this setup, let me know what you think
Compstar Forged 4340 3.48" Stroke Crankshaft
Compstar Forged 4340 H-Beam Rods
Mahle Forged Pistons (-5cc, -16cc, or -26cc)
Mahle Plasma-Moly 1.5/1.5/3mm Ring Package
Mahle Steel Pins & Wire Locks
Main and Rod Bearings Included
Internally Pre-Balanced by Callies/CompStar!
$2096
im planing on runing turbo, what pounds do you think this could handle,
im pretty sure once we get some stuff worked out ill be going with realquicks log turbo setup. im still up in the air with heads, i was thinkin the new dart pro or maybe le heads, like i said that part is still up in the air
Old Feb 6, 2008 | 05:35 PM
anything?
Old Feb 6, 2008 | 07:54 PM
ss.slp.ls1's Avatar
Looks like an all-forged short block. That's alot of money. What kind of power are you going for? You can make good power with a just a head and cam swap plus tunning.
P.S. I wouldn't repost the same question within 24 hours.
Old Feb 6, 2008 | 08:00 PM
looking for atleast 650 and anything after that is just a + just want to make for sure that the bottem end will hold up to alot more if i decide to go with that kit
Old Feb 6, 2008 | 09:18 PM
96capricemgr's Avatar
Once you consider everything in the setup that is the best value going for shortblock parts, "cheaper" options wont be much less expensive by the time you are done balancing and all. I do not however know if those pistons are up to boost.
I do think both of your topend choices are leaving something to be desired.
One Compstar dealer that ports LT1 heads has a car out there making just over 1000rwhp with a turbo and ported GM castings.
Old Feb 6, 2008 | 10:02 PM
SS RRR's Avatar
that assy. looks fine. what is more of a concern is how it's put together and what top end you use. you need to do a lot of research and decide for yourself. before you decide on a piston you must know what combustion chamber size you are going to run and what will complement your boost level. Build it from the top down.
Old Feb 6, 2008 | 10:10 PM
rskrause's Avatar
Moderator
Nice botom end parts at a decent price. Good shopping/choices.
Rich
Old Feb 6, 2008 | 10:33 PM
well im open for recomendation on the top assembly, id prob fell better with je pistons but this is whats with the kit, and i really havnt heard anything bad about mahle, i happened across the kit looking at ai heads on there website. like i said before all comments and recomendations are very greatfull and i thank you for your time and input on my build
raz0r6
Apr 29, 2005 12:39 AM
94 BLUE Z MR
Pacific
27
Feb 19, 2005 01:21 PM
94foormula
Jun 11, 2004 08:21 PM
Timberwolf
May 8, 2003 03:27 PM
Acct 23749
Aug 30, 2002 04:19 AM
