cc305 vs xe230/236
Old May 8, 2003 | 11:56 AM
Timberwolf's Avatar
cc305 vs xe230/236
opinons? a4 car... will be setup for street/strip use (mostly street killings)...
Old May 8, 2003 | 12:24 PM
bunker's Avatar
The 230/236 is more drivable & has more power all around & sounds better, trust me Its unbelivable but its because of its Xtreme Grind, I've installed almost all the cams, lt4 hotcam,cc305,xe 230/236,xe224/236,cc306,stock,gtp 5. the Xe 230/236 is my choice for now for every day driving, for the most power I think GTP 5 & cc306 but the Xe 230/236 is up there.
Old May 8, 2003 | 12:34 PM
Timberwolf's Avatar
what converter would you recommend? I am guessing around 3000 stall?
Old May 8, 2003 | 02:07 PM
ShelbyZ28's Avatar
What about with stock heads? Is the 230/236 still your choice? I'm also looking for a street/strip but mainly street cam but I want to run stock heads for now. I was looking at the 224/230 and 224/236 cams and was leaning towards the 224/236. I would have a dyno tune and the car is a M6. Would the 230/236 work better or should I stick with the 224/236? Thanks
Bryan
Old May 8, 2003 | 03:27 PM
magius231's Avatar
the 230/236 really should be used with ported heads, but many have run it with stock. If your going to stay with stock heads I would look at a smaller grind, but if your going to do heads in the future this is a great cam to do.
Russ95Z28
Apr 23, 2015 01:55 PM
pattymelt1285
West South Central
Feb 20, 2003 11:42 AM
Z95m6
Feb 14, 2003 03:51 PM
langtown77
Dec 20, 2002 11:27 PM
Z95m6
Nov 26, 2002 09:07 AM
