Need help with LT1/400 frankenstein swap
Old May 12, 2009 | 08:18 AM
bjf24ng's Avatar
Ok, here's the deal guys. I have a 97 z that's all stock except for a catback. I have a buddy with a TBI 400 that he built for his truck. Long story short, he doesn't need it anymore and is willing to part with it cheap. I know that to run a 400 I would need new injectors/fuel pump. Would I need new heads/intake/prolly lotsa other stuff?
Also, I'm fairly well mechanically inclined and he works on all of his vehicles, but he's only worked with TBI/TPI era cars, and I've never taken anything apart on my car. So, I need the voice of experience for help.
thx
Old May 12, 2009 | 08:20 AM
MeanGreen97Z's Avatar
More involved in this swap than you really want to do. This will cost more than if you built your own motor.
Old May 12, 2009 | 08:39 AM
bjf24ng's Avatar
That's why I was asking. I know that the LT1 heads would be a bad choice because they'd jack CR through the roof, but I can do pretty much anything with this 400, including rebuilding it from the ground up. I just want to know exactly what would be involved so I can be mostly prepared. (I say mostly because it's almost impossible to ever be completely prepared for something like this)
Old May 12, 2009 | 09:40 AM
bombebomb's Avatar
Will LT1 heads even work they are reverse cooled?
Old May 12, 2009 | 09:57 AM
bjf24ng's Avatar
I know they are reverse cooled, but having taken neither engine apart, I don't know if that would change anything. Does it make a difference where the coolant passages flow, or just to where the cooling system hooks up to the engine?
Old May 12, 2009 | 10:38 AM
red94chicken's Avatar
the lt1 heads will not work on the 400. its a bad idea. from top to bottom its a pain in the *** PERIOD. ignition, flywheel, engine mounts, accesories. if you are going to be able to rebuild a 400 why cant you do the same to the lt1? you realize you can get 400rwhp from a stock bottom end lt1 right?
Old May 12, 2009 | 04:24 PM
bjf24ng's Avatar
I'm not disagreeing you, I just thought it might have been better in the end to have a few more cubes pushing. Plus, it's not currently in the car, making it easier to work on. I know there's a lot of potential in the LT1, I just thought the 400 would be a little more potent.
Anyway, thanks for the input, guys. I appreciate everyone steering me away from a major pitfall before I was waist deep in it.
Old May 12, 2009 | 07:14 PM
Why not a 396ci LT1? Doubt you would notice the missing 4ci.
The LT1 heads can be converted to match the coolant ports on the Gen 1 SBC, but why bother. There are better heads out there for a Gen 1 SBC, without the need for conversion. And you would need to use the LT1 intake, which then requires modification for a distributor (since you no longer have the Optispark distributor) and the Gen 1 coolant passages.
Old May 13, 2009 | 11:42 AM
bjf24ng's Avatar
Since I'm building up the LT1 now, do I have to use only LT1/LT4 heads for reverse cooling, or will other SBC heads hook up? (You know, the little things nobody tells you)
Old May 13, 2009 | 12:08 PM
bjf24ng's Avatar
OK, disregard that last post. I had a "married" moment, and reading another post the light bulb lit. Thanks again, guys.
Old May 13, 2009 | 01:09 PM
bombebomb's Avatar
You can have sbc heads converted to reverse cooling, but it will cost you.
Old May 14, 2009 | 09:19 AM
bjf24ng's Avatar
After doing some research on the threads on this forum, I'm thinking more about Lloyd Elliot's LE2 package. It just makes a lot more sense, budget and otherwise. New heads and then having new heads either converted or ported... Too much expense for what I have under the hood right now.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
