96 LT-1 no start isues
Old May 12, 2009 | 10:15 PM
383TransAm's Avatar
Arrow 96 LT-1 no start isues
I'm trying to help a friend with his 96 TA that just up and died on him last night while we were out cruising.
We have 40 + LBS fuel pressure w/ key on and almost 50 cranking.
I have no spark at #1 plug or from coil to opti.
Voltage to ICM is 8.2 w/ key on (Pink wire)
Voltage to Coil from ICM is 8.2 w/ key on Pink wire)
I put a new coil on it and it made no difference.
Someone said the CPS would cause our issue?
I could really use some help here
Old May 13, 2009 | 05:26 AM
Did you scan it for codes?
CKP doesn't keep it from starting or running. Its just there to monitor for misfires. If it was bad, it would set a code.
Old May 13, 2009 | 05:51 AM
RobsWS6's Avatar
Did you check the iginition fuse?
Old May 13, 2009 | 07:38 AM
383TransAm's Avatar
Fuse's are all good.
No I didn't scan it for codes and it isn't throwin the SES light but I'll check it.
Old May 13, 2009 | 10:03 AM
383TransAm's Avatar
No codes what so ever and I have a Snap On scanner.
Old May 13, 2009 | 12:15 PM
bw_hunter's Avatar
No spark from coil to Opti could indicate that the computer isn't seeing a signal from the opti. Shoebox has a method for finding out: http://shbox.com/1/4th_gen_tech2.html#opti_test
Good luck!
Old May 13, 2009 | 10:50 PM
But that would set codes for the missing pulse signals.
Old May 13, 2009 | 10:57 PM
8.2v sounds suspect. It should have battery voltage there. If battery voltage is that low, then it isn't going to start, anyway.
Old May 14, 2009 | 10:09 AM
383TransAm's Avatar
Low batt so I went back and check again today and it comes back 11V.
Old May 14, 2009 | 11:02 AM
383TransAm's Avatar
After doing more checks on the Opti I believe it's my problem.
The Pink/Black wire from the opti grounds out and from the test I read that shouldn't happen.
So..........................................out comes the opti!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
sskevinm
Dec 18, 2014 11:16 AM
