Need help with keyless entry (shoebox)
Old Oct 9, 2003 | 11:23 PM
jasons93z's Avatar
I have keyless entry, but i bought a gm alarm that tapes into it.
Does anyone have a diagram of the keyless entry brain and what each wire goes to, such as trunk release etc..
Old Oct 9, 2003 | 11:43 PM
Just for you: 1995 Keyless entry schematic. The 1994 and 1995's are mostly the same when it comes to wiring.
Old Oct 12, 2003 | 11:01 PM
jasons93z's Avatar
nice diagram. But i really dont understand all of it. I found the keyless entry brain, and it has two wiring harnesses on it.
Old Oct 12, 2003 | 11:21 PM
Sorry, you asked for a diagram. It's a little hard to give a tutorial on how to read a schematic over the internet. I thought that maybe there was some wiring info with the alarm that might help you mate it up with this schematic.
In the schematic, there are letters by where the wires go into the receiver. Those correspond to cavities that are marked on the connectors that plug into it. If you see a C1 or C2 by it, that means connector 1 or 2. You can follow the lines for power and ground to the various items that are controlled by the receiver.
Old Oct 12, 2003 | 11:30 PM
jasons93z's Avatar
heres a pic of what im dealing with. I know that those wires go out to the doors, trunk, etc, i just nead to know what is what so i can tap into it for the alarm
Linky : http://f1.pg.photos.yahoo.com/ph/ou_...iew=t&.hires=t
Old Oct 12, 2003 | 11:43 PM
Well, the schematic shows what connector, what color wire and where each goes. I'm kinda at a loss as to how to help you more than that.
ex. On connector C2, C is a grey wire and G is a tan wire-they go to the LH power door lock actuator.
C2, H is a tan wire and a grey wire that is spliced off of C go to the RH door lock actuator.
The hatch release relay (not the one inside the receiver) is operated by C1, B that is a black wire.
Old Oct 12, 2003 | 11:55 PM
jasons93z's Avatar
actually, that REALLY helps. Now i know what to tap into.
Im never good at looking at those kind of schematics , thanks alot shoebox
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
WPHIG2
Aug 27, 2015 06:37 AM
bunker
Aug 21, 2015 10:21 AM
gelbza
Jul 12, 2015 08:10 AM
