need help! idle too low!
Old Aug 27, 2007 | 08:01 PM
bym's Avatar
bym
i just installed the LT4 hot cam on my 96 lt1, i have the hypertech for supercharged, cam, and headers. well i do not have a SC.. but its optional to install the program, well my problem is that the car is idling on 500 rpm or lower, so i used the hypertech to bring up the revs to 1000, and nothing happend, what should i check besides vacums. im probably gussing its my IAC or MAP... any sugestions????
Old Aug 27, 2007 | 08:09 PM
Dave89IROC's Avatar
Iac
Old Aug 27, 2007 | 08:21 PM
bym's Avatar
bym
Is there any way to clean the Iac not removing it from the TB?????????, since its a trip going there!
Old Aug 28, 2007 | 05:42 PM
Might want to test it before you remove it. Courtesy of Shoebox:
http://shbox.com/1/iac2.jpg
Old Aug 29, 2007 | 06:04 PM
bym's Avatar
bym
thanks ill check it before, well found the problem,,, the last owner of my car, had the egr unpluged since it was stuck and so, if there is an air leak the only posible way to lower rpm when there is a leak is closing the tb so i just opened it alittle bit with the torque screw and problem solved! 800,,, 850 rpm on drive! nice! thanks anyway!
andrewcapps82
May 19, 2015 10:11 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
camy 1993
Feb 3, 2015 06:26 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
