Need Fuel Pump Help!!!
Old Feb 4, 2004 | 08:42 AM
jameyab's Avatar
Does anyone know where to find the instructions for replacing the fuel pump WITHOUT dropping the axel. I saw one a while back where they just cut a square in the inside of the back hump of the car and pulled the fuel pump straight out of the top. Does anyone know where to find these or has done this before??
Old Feb 4, 2004 | 08:55 AM
gamecockfan04's Avatar
I did it and it was really easy. Just drill some holes (not deep, the gas tank is about 3" below) in the middle of the hump. Then I used a hacksaw blade and cut from left to right (the top, right, and bottom side) and peeled it to the left. The pump should be right below the hole. When your finished installing the pump just bend it back down and fab it up and I used alot of silicone to seal it good then put a thin piece of metal over it and screwed it down, so that it will still support weight.
Old Feb 4, 2004 | 10:41 AM
QCKZ28's Avatar
there is a link to a good guide in this thread
http://web.camaross.com/forums/showt...anel+fuel+pump
there are pros and cons of doing this, i decided to cut the access panel
jesse
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
