inch pounds to foot pounds??
Old Jan 28, 2004 | 03:57 PM
Zerosheaven's Avatar
how do you convert inch pounds to foot pounds??? is ther some kinda online calculator thing i can use?
Old Jan 28, 2004 | 04:02 PM
TQdrivenws6's Avatar
Just multiply by 1ft/12" thus canceling the inches, leaving you with feet.
So 24 inch-pounds * (1 foot / 12 inches) = 2 foot-pounds
Chris
Old Jan 28, 2004 | 04:03 PM
Mikey97Z's Avatar
LOL!!
divide by 12!
Old Jan 28, 2004 | 05:06 PM
hmmm....thats easy....maybe a little TOO easy....(looks around him suspiciously.....)
Old Jan 28, 2004 | 05:27 PM
OldSStroker's Avatar
Blame the Brits. They started the whole thing.
Yep, it's that easy. 1 ft-lb = 12 inch-pounds, and 12 in-lb = 1 ft-lb.
Don't ask about Newton-meters.
Old Jan 29, 2004 | 11:26 AM
bn_bullet's Avatar
If you would like to be able to convert units of measurement, there is a cool program called Convert that will allow you to do this easily. I use it all of the time for difficult conversions. You can download it for free here:
http://www.joshmadison.com/software/convert/
I think you guys will like it.
Brian
Old Jan 29, 2004 | 11:39 AM
Grover's Avatar
That program rocks, I use it all the time at work.
Old Jan 29, 2004 | 01:31 PM
BigRich's Avatar
another confusing thing is it's actually pounds per foot, or pounds per inch. that's why it's written 2 lbs/ft not 2 ft/lb
everybody says foot pounds and inch pounds but it's really 2 lbs of rotational force on a lever assumed to be 12" long
so 350 lbs/ft is like having 350 lbs on the end of a 12" lever arm exerting a rotational force.
Old Jan 29, 2004 | 01:36 PM
94formulabz's Avatar
I use that program at work too.
I always thought that it was an inhouse developed application though, guess not
-brent
Old Jan 29, 2004 | 01:45 PM
Is it not lbs times the distance rather than divided by the distance? Force times distance is definition of torque. Just the notation I question: your verbal concept is correct.
Old Jan 29, 2004 | 03:29 PM
Mikey97Z's Avatar
Right. It's "foot pounds" or "ft*lbs", not "feet per pound" which is "ft/lbs".
Old Jan 29, 2004 | 03:34 PM
94 NO TOP Z's Avatar
Correct! FT-LBS
Old Feb 2, 2004 | 09:37 PM
BigRich's Avatar
sorry, the / is not a division sign, but 'per' like 350 lbs per foot of torque
no that's wrong. it is vernacular and actually incorrect.
Originally posted by 94 NO TOP Z
Correct! FT-LBS
wrong again bucko, see my first post
when all else fails... HowThingsWork
now do you believe me?
Old Feb 2, 2004 | 09:59 PM
eyeoutthere's Avatar
No, you are wrong.
Read the page
HowThingsWork
it is ft*lbs NOT ft/lbs or ft per lb.
Old Feb 2, 2004 | 10:08 PM
Do I believe you? Absolutely not. 350 lbs/ 1 foot is a spring rate, not a measure of torque. And 350 lbs per foot of torque? Doesn't make any sense to me, 'of torque'. I thought torque was what we were talking about, you can't have torque defining itself.
You should actually go read howstuffworks yourself before you attempt to use it as a reference disproving a degreed engineer and two other guys in agreement with him. Not suggesting that engineers don't make mistakes, but thats not the case here.
Edit* BTW, i gave you the benefit of the doubt that you may have found an error at howstuffworks and looked there for myself. I don't see anything there supporting your claim.
(from howstuff works)
torque equals force multiplied by distance
English units of torque are pound-inches or pound-feet
pounds-inches or pounds-feet which is the same as pounds*inches and pounds*feet respectively, NOT pounds per inch, NOT pounds per foot, NOT pounds/inch, and finally not pounds/ft.
-brent
