Need advice on guideplates....
I'm getting ready to install an 847 cam with 1.6 Pro Magnum non-self aligning rockers and most likely 1 piece pushrods. I'm going to buy the rockers from someone who also has Comp Cams raised pushrod guideplates part #4800-8. He isn't sure if these will work on an LT1. Should I buy them or should I get something else?
Thanks!
Thanks!
COMP does not make guide plates to fit an LT1!
The LT1 has .050" wider valve spacing than a typical SBC.
I'm using GM Performance Parts (GMPP) guide plates with my COMP 1.6 "Pro Magnum" non self-aligning rockers. They're less than $20 a set.
Frank
Frank
Originally posted by shoebox
The guideplates I got from CM didn't line up the pushrods as well as the GMPP (p/n 14011051) ones do.
how many of these plates are needed? 8?
Any recommendations for locators? (i noticed you had them listed on the cam R&R page)
Thanks!
Those are the springs I will be using as well. Do I need to order a new set of locators or can I reuse the existing ones?
(again, the reason I'm asking is because you had them listed in the "parts needed" section)
Thanks!
Thanks!
Thanks!
Thanks!
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
