Need advice on guideplates....
Old Oct 19, 2003 | 04:55 PM
madwolf's Avatar
Arrow Need advice on guideplates....
I'm getting ready to install an 847 cam with 1.6 Pro Magnum non-self aligning rockers and most likely 1 piece pushrods. I'm going to buy the rockers from someone who also has Comp Cams raised pushrod guideplates part #4800-8. He isn't sure if these will work on an LT1. Should I buy them or should I get something else?
Thanks!
Old Oct 19, 2003 | 05:13 PM
Z95m6's Avatar
i would pass on them. i have heard that people have a hard time getting guide plates to work on LT1 heads i got the GM guide plates from thunder racing at 2.50 a piece and they work great.
Old Oct 19, 2003 | 05:18 PM
12SCNDZ's Avatar
COMP does not make guide plates to fit an LT1!
The LT1 has .050" wider valve spacing than a typical SBC.
I'm using GM Performance Parts (GMPP) guide plates with my COMP 1.6 "Pro Magnum" non self-aligning rockers. They're less than $20 a set.
Frank
Old Oct 19, 2003 | 05:36 PM
turbo_Z's Avatar
my RRs came with guideplates that were supposidly comp and they didnt line up all that great.
Old Oct 20, 2003 | 04:03 PM
R_Andersen's Avatar
Madwolf,
Give cmotorsports a call. I used their guideplates and hardened pushrods. They were very inexpensive and valvetrain geometry came out perfect.
-Rob A.
Old Oct 20, 2003 | 04:40 PM
The guideplates I got from CM didn't line up the pushrods as well as the GMPP (p/n 14011051) ones do.
Old Oct 20, 2003 | 10:59 PM
madwolf's Avatar
Rob,
how many of these plates are needed? 8?
Any recommendations for locators? (i noticed you had them listed on the cam R&R page)
Thanks!
Old Oct 20, 2003 | 11:06 PM
Yes, 8 are needed. I used the stock locators with no problems with the CM (612's, I think) springs.
Old Oct 20, 2003 | 11:09 PM
madwolf's Avatar
Those are the springs I will be using as well. Do I need to order a new set of locators or can I reuse the existing ones?
(again, the reason I'm asking is because you had them listed in the "parts needed" section)
Thanks!
Old Oct 20, 2003 | 11:34 PM
Thanks!
There was nothing wrong with my original ones, so I reused them. I guess I have them in that list so that people won't forget that they should use them.
Old Oct 20, 2003 | 11:42 PM
Dave88LX's Avatar
Off-topic, but similar...it's been a while since I've seen my heads
Do they use push in, or screw in studs for the rockers?
Old Oct 21, 2003 | 07:27 AM
R_Andersen's Avatar
Screw in studs....
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
