Need advice on guideplates....
I'm getting ready to install an 847 cam with 1.6 Pro Magnum non-self aligning rockers and most likely 1 piece pushrods. I'm going to buy the rockers from someone who also has Comp Cams raised pushrod guideplates part #4800-8. He isn't sure if these will work on an LT1. Should I buy them or should I get something else?
Thanks! |
i would pass on them. i have heard that people have a hard time getting guide plates to work on LT1 heads i got the GM guide plates from thunder racing at 2.50 a piece and they work great.
COMP does not make guide plates to fit an LT1!:alert:
The LT1 has .050" wider valve spacing than a typical SBC. I'm using GM Performance Parts (GMPP) guide plates with my COMP 1.6 "Pro Magnum" non self-aligning rockers. They're less than $20 a set. Frank |
my RRs came with guideplates that were supposidly comp and they didnt line up all that great.
Madwolf,
Give cmotorsports a call. I used their guideplates and hardened pushrods. They were very inexpensive and valvetrain geometry came out perfect. -Rob A. |
The guideplates I got from CM didn't line up the pushrods as well as the GMPP (p/n 14011051) ones do.
Originally posted by shoebox The guideplates I got from CM didn't line up the pushrods as well as the GMPP (p/n 14011051) ones do. how many of these plates are needed? 8? Any recommendations for locators? (i noticed you had them listed on the cam R&R page) Thanks! |
Yes, 8 are needed. I used the stock locators with no problems with the CM (612's, I think) springs.
Those are the springs I will be using as well. Do I need to order a new set of locators or can I reuse the existing ones?
(again, the reason I'm asking is because you had them listed in the "parts needed" section) Thanks! |
Originally posted by madwolf Those are the springs I will be using as well. Do I need to order a new set of locators or can I reuse the existing ones? (again, the reason I'm asking is because you had them listed in the "parts needed" section) Thanks! |
Off-topic, but similar...it's been a while since I've seen my heads :(
Do they use push in, or screw in studs for the rockers? |
Originally posted by Dave88LX Do they use push in, or screw in studs for the rockers? |
