Is my pcm fried??
Old Jan 13, 2009 | 03:07 AM
SmokinZ28lt1's Avatar
Question Is my pcm fried??
K well I have a 1994 z28 lt1 6spd and here is my problem when I accelerate rapidly and its gets between 4500+ rpm its starts cutting out almost like its being starved for fuel and backfires once in a while. These are the codes that it set #26 Quad driver module 1 fault,#22 Throttle position sensor too low #43 esc module or sensor circuit problem and #84 downshift feedback fault. My uncle who is a mechanic said my pcm could be junk? but idk i just want to get a second opinion before i spend $175 on a new one.
Old Jan 13, 2009 | 04:08 AM
SS RRR's Avatar
Year of vehicle, list of mods and some documentation to what you've done to the car before/after this happened may be helpful.
Old Jan 13, 2009 | 07:11 AM
You just need to get on with fixing some stuff. PCMs rarely go bad. Sounds like you have some wiring/electrical issues.
26 Evaporative Emission (EVAP) canister purge solenoid valve circuit
22 Throttle Position (TP) sensor circuit (signal voltage low)
43 Knock Sensor (KS) circuit
84 Skip shift solenoid circuit (manual transmission)
Old Jan 13, 2009 | 05:35 PM
Next time, use Shoebox's list of LT1 codes. The last year for the "Quad Driver Modules" was 1993. That is not the correct description for a 94.
http://shbox.com/1/Dtcs.htm
PCM's seldom fail. For example, does the skip shift solenoid prevent you from shifting 1->2 at part throttle? If not, its likely someone pulled the harness connector off the solenoid on the side of the tranny, to defeat the system. Open circuit sets the DTC 84 code, and does not hurt anything. The code can be eliminated with a 2Kohm resistor.
Knock sensor code is easy to track down. Pull the harness connector off the sensor, and measure the voltage between the single wire in the harness, and the block. Should be 5V. Then with the connector still off, measure the resistance of the knock sensor, from the single pin on the sensor to engine block. Should be in the range of 3,500-4,500 ohms. That code is causing you a significant performance loss, since the PCM will retard the ignition timing almost constantly.
Evap purge solenoid is easy to check as well, and you can put the volt meter across the TPS sensor and check the voltage for dropouts as you slowly rotate the throttle, and wiggle the connector. If you want details on these two, let us know.
Old Jan 14, 2009 | 11:19 AM
The car is completely stock the only think that isnt is a k&n cold air intake
Old Jan 14, 2009 | 11:34 AM
Yea could I get the details for those two?
Old Jan 14, 2009 | 10:27 PM
bump
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
