My LT1 feels sluggish...
Old Feb 19, 2011 | 04:31 PM
  #16
raroz28's Avatar
Re: My LT1 feels sluggish...
Originally Posted by my1994z28
Try unplugging the Maf.
Mike, shoulda called you a long time ago.
That made it run 100x better. When I punch it at WOT it takes off like a scared cat and there is no pressure on the gas pedal anymore.
WTF? So I need a new MAF?
Old Feb 19, 2011 | 08:12 PM
  #17
my1994z28's Avatar
Thats what it looks like..
Old Feb 19, 2011 | 11:12 PM
  #18
cthomson21's Avatar
Sorry for the waste of money on the MAF cleaner...... I think you can check it with a meter to see if there is some voltage fluctuation, but not sure on that. You could ask Injuneer or someone with more knowledge what that voltage should be..... Or if you have some scanning software and a plug you can check and see what you mass flow rate is into the motor.....Not sure with an OBD2 how easy this is though....
Old Feb 19, 2011 | 11:51 PM
  #19
MikeGyver's Avatar
The MAF spits out a freq from about 1500 - 11,000hz, not voltage.
4th walbro? what's up with that?
Old Feb 20, 2011 | 09:56 AM
  #20
I'm still not sure why a faulty MAF would cause an upward pressure on the accel pedal?????
The 97 (OBD-II) should also set a code if the MAF reading is not consistant, within a certain percentage, of the mass air flow calculated using the speed-density method.
Old Feb 20, 2011 | 06:40 PM
  #21
raroz28's Avatar
What would cause the upward pressure? The car feels stronger with it unplugged but perhaps it's just s lightly better but not 100%. I haven't driven it enough to know.
Old Feb 22, 2011 | 08:07 AM
  #22
raroz28's Avatar
It wasn't a waste. I didn't know there was a way to clean a MAF. I think from running with a dirty filter so long, I ruined the MAF. I mean, I took this stock air filter out when I put in my K&N 5 years ago and the filter was dirty then. I put that same stock filter back on 2 years ago and when I took it out I can't explain how filthy it was. It had a broken fuse in it, leaves, and it was super black.
When I had the hood open with the car running it was so fumey and stinky and once I replaced the filter it went away. It just slipped my mind to ever even look at it, I really just forgot about it. I am sure that my MAF is filthy or perhaps I even did permanent damage to it.
Old Feb 22, 2011 | 03:27 PM
  #23
raroz28's Avatar
Just thought I would update this.... I pulled my battery out to put it into another car. It was out for an hour or so.
When I put it back in and started the car out, the hiccup and missing was gone and it was much, much smoother.
The car is running what seems to be 100% and has no misfire whatsoever.
This is strange because after I fiddled with and cleaned the MAF, I pulled the pcm bat fuse for about a minute and put it back in.
Perhaps the PCM just needed a good reset?
Feels good to be back up to power.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
willismoons
Feb 14, 2015 08:42 PM
ro2207
Dec 4, 2014 06:18 PM
