My LE Head Flow #'s
Old Jun 15, 2004 | 06:22 PM
  #16
jkipp84's Avatar
Odd, Lloyd told me LE1 heads have stock valves. I think I'll go with what he said
EDIT: Apparently I'm not the only one told this. Check this thread out. Scroll to the last post.
Old Jun 15, 2004 | 06:43 PM
  #17
Spinner's Avatar
Which doesnt mean you can't get big valves in the heads and an LE1 cam. Stage 1,2,3, is all just silly. Lloyd will do what you want with your heads, promise
LE2/3 heads do COME with bigger valves, but the port job isnt any better/worse.
Old Jun 15, 2004 | 06:48 PM
  #18
simple's Avatar
Originally posted by amean94ta
the exhaust looks alittle weak mine are 271/230 at .6000 but krs did mine
KRS?
230, sure....done with a pipe, even that seems a little high
Old Jun 15, 2004 | 07:00 PM
  #19
Andrew04ME's Avatar
Mystic, how much did you pay for the heads/cam package if you don't mind?
Old Jun 15, 2004 | 08:56 PM
  #20
brain's Avatar
Hmm... Did you skip the first post where he says he got 2.00/1.56 valves installed?
Old Jun 15, 2004 | 10:00 PM
  #21
Mystic97Z's Avatar
they are le1 heads, i just paid x-tra for the bigger valves,,
i supplied some parts, so the price is kinda variable.
it was rouphly a grand for the heads as stated b4, and like 400 for the cam i think, the valve job was a lil xtra too
Old Jun 15, 2004 | 11:06 PM
  #22
97Z-M6's Avatar
i hope mine are good i just got the valves today. hes got the heads allready. i putting 2.05 and 1.56 goingt o have new seats put in the intake. so i hope i get good numbers out of them.
ive got the le1 cam. but i wish i had the le2 but we will se how she works.
230 on a lt1 stock head. i would like to see loyd flow those heads and see what he gets. by the way what lift was that at.
Old Jun 16, 2004 | 01:42 AM
  #23
1982z28with18s's Avatar
Numbers look close to mine from him. I'm running a custom cam from Joe O. thats 220/226, smaller than the LE1 cam. Before tuning I made 384rwhp/363rwtq. I'm positive its a little over 400rwhp/375-380rwtq now with tuning(pcmforless). I've ran a best of 11.710 at 116.76 with it also. He also did port my intake for me, and I'm running a stock TB still.
Old Jun 16, 2004 | 03:33 AM
  #24
jkipp84's Avatar
Right, I never mentioned that you can't get your heads done however you choose, that's up to you and your check book. I was just pointing out that the description of LE1 heads includes stock valves.
He's got my heads right now He also worked with me a on going with beehives & ti retainers with the LE2 package instead of 987's.
Old Jun 16, 2004 | 03:53 AM
  #25
formula383's Avatar
jkipp84, I have spoke with Lloyd about porting my LT4 heads ask about the beehive springs and he said he had one customer going with them right now so I guess that is you.
Keep me updated on how you like the setup if you don't care. I am interested in going this route but would like to see someone run the setup first.
If it isn't too much trouble what all parts did you have to get along with the springs? part numbers please.
Old Jun 16, 2004 | 02:04 PM
  #26
jkipp84's Avatar
Looks that way!
formula383,
I'm not sure about the pn's but it wound up being extra $100 or so. Lloyd is going to handle getting them.
You might try him or Bret or even Comp to find out what all is appropriate for the cam you're going to use with them. I have absolutely no idea if machining is required, btw.
Old Jun 16, 2004 | 07:20 PM
  #27
IrocSS85's Avatar
my heads flow 184 w/o pipe at .600, and they flow 210 at .600 with the pipe. seems feasible to me. but poss. a little bloated #s. the #s look great to me. wish I could see some pics of lloyds port job to see what the big diff. is between his port jobs and how I did mine. I think the overall shape of his ports are why he gets those good flow #s, not just that they are more hogged out then mine.
chris
Old Jun 16, 2004 | 09:27 PM
  #28
amean94ta's Avatar
yeah my heads do flow 271/230 at .6000 without a pipe. not fudged # i am running ferra super flo's 2.02/ 1.60 all the numbers underneath are also corrasponding i will get my sheet when i get back to the shop for exact #'s. i work there and are porter chuck spent 40 hours flowing then reporting them to get what he wanted to match my 396 stroker i just built there. trust me you guys will see some big things coming from krs. we are a machine shop for pro mods and outlaw's also top fuel but i am just starting to get my "cousin the owner" to see there is money in street cars also
Old Jun 17, 2004 | 06:00 PM
  #29
formula383's Avatar
jkipp84, thanks. I have talked to Bret about them and got prices. I will probably go this route expecially since I now know that no machine work is required for them to work so it will end up cheaper than the doubles.
Old Jun 17, 2004 | 06:36 PM
  #30
Spinner's Avatar
Sorry, they dont. That isnt possible with a factory LT1 casting. Something was off, either the flower, the bench, or otherwise. 230 EX isnt going to happen
