My engine setup (advice/opinions)
Old Jan 28, 2006 | 10:07 AM
Honda Hunter's Avatar
My engine should be done soon (Enshala) so heres my setup:
Eagle 4340 383 stroker kit
Eagle 4340 5.850 H-Beam Rods
Eagle 4340 3.750" Internal Balance Crankshaft
SRP -5cc Pistons
Upgraded oil pump
Vented Optispark conversion
Cloyes Timing chain
LT4 ported intake manifold
ASP crank pulley
Moroso deep sump oil pan
Meziere electric water Pump
AFR 190 Lloyd Elliot port and polished 217cc heads
Lloyd Elliot / Bret Bauer custom cam
Comp 977 dbl springs and Ti retainers
Crane energizer series non slef aligning Rocker arms
AFR guide plate
AFR one peice chrome moly pushrods
Racetronix 37lbs injectors
Racetronix fuel pump with harness
Taylor spark plug wires
Hypertech 160 thermostat
BBK 58mm Throtle Body
Moroso Cold air intake
MSD 6AL ignition
MSD blaster coil
4 bolt block
4.10 gears
315/35 BFG drag radials
-In 2 weeks or so
ATI balancer
200+ NX kit
How does this setup sound and is there anything else anyone can think of I should add to make more power? This is all for a 1994 Z-28 Convertible.
Old Jan 28, 2006 | 10:37 AM
JustNO's Avatar
Re: My engine setup (advice/opinions)
Head flow numbers?
Old Jan 28, 2006 | 10:45 AM
mattybz28's Avatar
Get ET Streets.
Old Jan 28, 2006 | 10:54 AM
Originally Posted by JustNO
Head flow numbers?
.2 138/107
.3 194/143
.4 242/178
.5 274/199
.6 285/211
.650 288/214
Old Jan 28, 2006 | 11:28 AM
JustNO's Avatar
Your complete setup is very similar to mine,(including injectors,BBK TB...) except you got A4, I have M6. Let me know when you get dyno numbers.
Old Jan 28, 2006 | 11:45 AM
As soon as it's broke in I want to get it tuned. I just hope it makes over 400. Seems like most 383's Ive seen on the board dont break the 430 mark. Do you plan on going to the dyno?
Old Jan 28, 2006 | 12:29 PM
JustNO's Avatar
You should easyly see 400+ . I hope I will see 440-450rwhp with 10 bolt rear end. (I will not take her to the track until I get 12 bolt)
Old Jan 29, 2006 | 09:53 AM
I hope to get away with not having a 12 bolt at least till I get back stateside.
Old Jan 29, 2006 | 02:49 PM
12SCNDZ's Avatar
When I started doing reseach for my 355, I originally looked into SRP pistons. It seems as though they're not recommended for anything over a 150 shot. SRP pistons have a high silicone content. I was told this directly from JE/SRP's tech department. The only nitrous piston JE makes would give me 13:1 + compression, because it's a domed piston. After much research, I settled on the Ross nitrous piston. The top ring is .150" down, and it's a flat top.
Frank
Old Jan 29, 2006 | 09:31 PM
Wow, I didnt know that. No problem though. Ill just do a 150 shot. Thanks for the info.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
CaRParts102
Dec 6, 2014 08:45 AM
