My Cap and rotor bad? (PIC INSIDE)
Old Apr 11, 2005 | 10:04 AM
Royce Friesen's Avatar
Well I developed a low RPM miss (not bad, but enough to bother me) so I went ahead and pulled the cap, and this is what I found. Would these three points be a cause for it? The plasit below them looks almost burnt, or corroded, or something. Thanks in advance, Steven.
Old Apr 11, 2005 | 10:10 AM
Z28WannaB's Avatar
Re: My Cap and rotor bad? (PIC INSIDE)
My friend just replaced his cap and rotor and his car ran fine afterward. My car ran fine for a long tme, and when I pulled my opti the inside looked really corroded on those pins.
I just replaced the whole opti, why pay 130 dollars when for 100 more you can do the whole thing right.
In my opinion it would suck to have to take it off and do it all over again.
- Z28WannaB
Old Apr 11, 2005 | 12:42 PM
BRIAN93Z28's Avatar
- Z28WannaB
Ill second that...optispark is a PITA
Old Apr 11, 2005 | 12:45 PM
turbo_Z's Avatar
That definitely isnt right. I wonder if what you are seeing is where the metal conductor on the end of the rotor is actually contacting the cap.
Old Apr 11, 2005 | 01:42 PM
Appears to me to be "carbon tracking". That will cause misfiring between cylinders.
What does the tip of the rotor look like? Is it burned, causing the spark to have to jump a large gap to the contacts on the car?
Old Apr 11, 2005 | 06:31 PM
The rotor does look burnt too...
What sucks, is that I can't get ahold of the MSD cap and rotor for my life right now...
Old Apr 11, 2005 | 06:34 PM
Bersaglieri's Avatar
Try Summit? I know they advertise them, hopefully they have them in stock.
-Dustin-
Old Apr 11, 2005 | 07:44 PM
1racerdude's Avatar
Looks like you have some high resistance on the wires to those cyls. causing the spark to jump back to the cap. It sure looks like carbon.Ya need to check the wires on those cyl's against another wire about the same length and see the ohm difference,if any. And your plugs could be wider than they should be.Set them at .035 and get rid of that problem with them.
Old Apr 11, 2005 | 07:47 PM
cas0484's Avatar
Goodluck with the MSD cap/rotor. Summit and Jegs both have them on backorder till may or june
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
omarECD
Aug 19, 2002 07:28 AM
