Power from porting?
Old Apr 10, 2005 | 11:54 PM
JDMZ28's Avatar
Power from porting?
Is there power to be gained just by gasket matching the heads and intake? Anybody tried this. Just wondering if they are a restriction or not.
Old Apr 11, 2005 | 08:35 AM
WS Sick's Avatar
Re: Power from porting?
If you only gasket match them, you would notice not a thing. The restriction is the few inches either side of the valvejob, after that is opened up then the opening at the port may become a restriction.
Old Apr 11, 2005 | 08:48 AM
raroz28's Avatar
You will get the most gains from a 3 angle valve job and porting the inside of the heads - bowl blend. Dont' get sold on the 5 angle, it's a gimmick and you will not notice any difference between it and the 3 angle. It's just more $$$ for the shop. I have been told this by many machinists, head guys, etc...
But to more directly answer your question, yes it will help and make power. Simple really. Bigger ports = more flow, more flow = more HP.
Old Apr 11, 2005 | 07:54 PM
JDMZ28's Avatar
Thanks guys, I figured as much but wasn't sure if this was the case for LT1 heads.
oldschool
Feb 9, 2016 09:21 PM
4586
Apr 29, 2015 01:43 PM
Roadie
Feb 16, 2015 10:34 AM
XtremeLt1
Sep 13, 2002 08:50 PM
