My bolt on 96 camaro build.
Old Oct 9, 2013 | 01:24 AM
CORTEZ2095's Avatar
Hi guys. Im new too this forum. I really appreciate it if u guys help me wit my 96 LT1 build. Ok. My first thing is i wana put headers. Im thinkin longtube pasecetters cermic coated of course. So my questions is are these headers the best bet for me & how much hp increase will this be ? & next check i also wana do a full catback exhaust wit a y-pipe true dual. Is this a great first step? Pls answer back ! Thanx & most appreciative.
Old Oct 9, 2013 | 03:08 AM
Chet1185's Avatar
Re: My bolt on 96 camaro build.
Don't forget the cai, if you don't already have one.
Check this out, looks decent.
http://www.ebay.com/itm/151063281516?redirect=mobile
I'm on the full site on my phone but it looks like its using the mobile site yet.
Sent from my R800x using Tapatalk 2
Old Oct 9, 2013 | 07:41 AM
JakeRobb's Avatar
Super Moderator
Pacesetters are cheap, mild steel. They'll rust. Also, the more expensive stainless steel LT headers tend to flow a bit better and are sometimes easier to install. If you can afford it, I highly recommend them.
You can't have true duals and a Y pipe. That's contradictory. True duals would use an X pipe, or possibly an H pipe, or maybe none of the above - but definitely not a Y pipe.
Old Oct 9, 2013 | 09:36 AM
Ceramic coating (which he indicated he would include) should prevent or at least minimize rusting of mild steel, while offering additional benefits like reduced underhood temps, improved scavenging/HP, reduced cyclic heat stress cracking, compared to uncoated mild or stainless steel. I know that some of the coatings don't seem to hold up well in areas that use heavy amounts of salt in snow/ice conditions. But it appears he is from CA based on the IP address.
Of course if he is in CA, that raises a whole new issue regarding the legality of long tube headers.
Old Oct 9, 2013 | 04:18 PM
CORTEZ2095's Avatar
Thanx guys appreciate the insight ! Yeaa i mean x-pipe idk why i said y pipe. Wat else would u recommend for my bolt on LT?
Old Oct 10, 2013 | 07:07 AM
z2894convertible's Avatar
Underdrive pulley.
Old Oct 10, 2013 | 04:19 PM
Here's some dyno tests of common LT1 mods:
WS6.COM LT1 Trans Am
For example, the throttle body coolant bypass (free mod) is worth 6 peak HP. An underdrive pulley gains 0.7 peak HP, and can cause charging problems on automatics with their low idle speed. Do you have a manual or auto trans?
You still need to clarify your exhaust plans. If you use an X-pipe, you can't use a "full catback exhaust". A "catback" is typically a single pipe, to a cross-flow muffler, with dual outlets. But you indicate you want true duals.
You need to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. It gets appended to all your posts, so people have the info to help you.
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
Collector Car
Jan 5, 2015 10:58 AM
Catmaigne
Dec 25, 2014 12:16 PM
