EGR Control Valve / Solenoid
Old Oct 11, 2013 | 07:46 PM
1996LT1Z28's Avatar
What signals / voltages should I be reading when checking to see if the EGR valve solenoid is on / off. I want to make sure the egr is getting vacuum when it's supposed to.
Thanks for the help.
Old Oct 11, 2013 | 08:26 PM
Re: EGR Control Valve / Solenoid
The solenoid has 12V on the brown wire when the ignition is on. The PCM provides a pulse width modulated ground on the gray wire to send the required vacuum to move the valve to the desired opening. EGR does not operate at WOT, at idle or over 3500 RPM. The degree of opening varies with engine operating conditions.
If the solenoid circuit is faulty it will set a code. If there is no actual EGR flow when there is supposed to be, you get code. The OBD-2 diagnostic will usually pick the lack of flow up. The OBD-1 diagnostic is hit or miss.
You can read the PWM % with a scanner or scan software.
Old Oct 12, 2013 | 10:12 AM
1996LT1Z28's Avatar
Thanks for the help injuneer!
appreciate it!
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
NewsBot
Apr 20, 2015 03:00 PM
edman
Mar 13, 2015 09:39 PM
Jul 4, 2005 05:00 PM
