MSD Failure Analysis - Pictures
Old Jan 12, 2007 | 02:17 PM
  #61
Not sure I understand - cover for what? The "cap" is the cover. You use the entire Opti, less the rotor if you decide to remove it. The optical module is fastened to the rear 1/2 of the housing. From Mike Chaney's Opti Disection Page:
Old Jan 12, 2007 | 03:08 PM
  #62
rob97ss's Avatar
Originally Posted by 1FstFormulaV8
I have been pondering the idea of just using the "Opti Module" with Delteq. I had been wondering where to pick up an Opti cover. Where and how much did you get pay for the cover?
Delteq sells a billet cover for $95.00
Old Jan 15, 2007 | 09:00 AM
  #63
SweetZRag's Avatar
I just wanted to update anyone interested. The MSD Opti now has 11,000 miles on it. The engine has 321,000 miles. Still no issue with the MSD.
Jeff
Old Jan 15, 2007 | 12:10 PM
  #64
IgorT.455/406's Avatar
Jeff
Holly Jeff, you did put a lot of miles on yours. I parked mine at end of september for the winter, will be pulling it out i assume in march.
Got 3k miles or so on mine, zero prob.
Old May 7, 2007 | 12:17 PM
  #65
Josh3111's Avatar
my MSD is giving me trouble right now also, which is why I am researching on it right now. My car is sputtering and misfiring up to 3000 rpm's which is similiar to the regular analysis. I have changed my plugs, wires, coil, check fuel injectors and whole fuel system for that matter, the only thing left is the @#$%ing opti-spark. Really wish I would have bought an LS1. So I am gonna check for the red dust, and see if that is the problem. I better get my money back for that piece of @#$%, is all I have to say.
Old May 7, 2007 | 02:56 PM
  #66
mrmint69's Avatar
I looked up under the car and noticed the cover is slightly off. One side is down further than the other side. I have the car running perfectly but i will be pulling it if it has any problems. The cover screws are very soft and hard to remove once there in.
Old May 8, 2007 | 09:40 AM
  #67
SweetZRag's Avatar
Josh, sorry to hear about your problem. Since I got the new one from MSD, I now have 13,000 miles with no more issues. If you have the same problem I did, it will be obvious once you open the cover. Good luck with it.
Jeff
Old May 8, 2007 | 10:40 PM
  #68
Josh3111's Avatar
so there was red dust in there on mine....didn't you say they rebuilt it for you?
Old May 9, 2007 | 11:10 AM
  #69
Z-RATED94's Avatar
Where may I ask is the qualiy control on these pieces?
Noenav
Mar 1, 2019 07:38 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Injuneer
Dec 15, 2014 09:36 AM
