MSD Failure Analysis - Pictures
Old Aug 11, 2006 | 11:51 AM
  #31
Makaveli's Avatar
Re: MSD Failure Analysis - Pictures
very interesting writeup and analysis. good luck!
Old Aug 11, 2006 | 01:01 PM
  #32
Sweetred95ta's Avatar
Originally Posted by thesoundandthefury
A sheet of paper is 40 thousandths of an inch thick.
http://72.14.203.104/search?q=cache:...s&ct=clnk&cd=1
According to that link, the average piece of paper is 1/1000 in. thick. I thought paper was like 4-6 thousandths of an inch thick, but I haven't checked in a long time.
Old Aug 11, 2006 | 01:25 PM
  #33
thesoundandthefury's Avatar
1/1000's was the unit of measure for the legend in the table. Here are all of the actual measurements:
TEXT PAPERS 25x38
50# OFFSET .0040 60# ENAMEL .0030
60# OFFSET .0045 70# ENAMEL .0045
70# OFFSET .0050 80# ENAMEL .0040
100# OFFSET .0070 100# ENAMEL .0050
Old Aug 11, 2006 | 02:27 PM
  #34
TEXT PAPERS 25x38
.004 in = 4 thousandths of an inch, not 40 thousandths.
I was wondering about the "1/1000 in" thing. They have that, but still give the values as ".004 in" and not "4".
Old Aug 11, 2006 | 03:40 PM
  #35
Yes, .004 is 4 thousandths, but that's not what the table says is it? Read the numbers outlined in bold again.
A little math refresher course:
But hell, I like to play devil's advocate as much as the next guy, so let's just go along with your standard of measurement and use it as a point of reference. So let's just say that a sheet of paper is 4 thousandths of an inch thick: this would mean that the area of tolerance that the tech at MSD had determined was too far out of spec was actually ten times smaller than that. So now, the "o-ring pinch" which led to the backing plate being bent had bent it so severely out of spec that we couldn't even fit 1/10th the width of a sheet of paper into the used up clearance.
Sound ridiculous enough yet?
Old Aug 11, 2006 | 07:41 PM
  #36
Mtrhds94Z's Avatar
Originally Posted by SweetZRag
I received the first feedback from MSD today. I spoke to a gentleman named "JD" who I understand is the responsible technical person for the Pro-Billet Opti product line.
JD told me he personally has installed about 30 of the MSD units and has not had a problem with them. He tried various ways to recreate what happened to my unit and could only come up with one possible explanation. He believes the O-ring folded over during the installation causing uneven pressure on the unit. This caused the black backing plate under the rotor to bow up and rub the back of the rotor. He said my plate was bowed about 30 thousands in the center. As mentioned in my analysis, there are signs the O-ring was pinched.
I am not sure how the billet back plate could flex enough to cause the bowing he described. Especially when I only used a screwdriver to secure the cap. I was also very careful to make sure the O-ring was properly seated before installing the cap.
I should receive the unit back in time to reinstall on Sunday. JD said he will install all new guts before returning. Before I do, I will take a closer look at how the O-ring could have caused the bowing and update this post.
Jeff
First underlined sentence says:
Second underlined sentence says:
One contradicts the other as the 'black backing place' is not the 'billet back plate? It makes some sense to me that the black [intermediary?] plate could bow or be 'raised' .030 [thirty thousandths] by a folded oring.. and that would cause the rotor to rub as described..
Hard to believe that it wouldn't be noticeable tho, at least upon your inspection after removal? Did you take the rotor and plastic black plate off before sending it back to MSD?
soundandthefury:
The paper thickness table:
TEXT PAPERS 25x38
is in ten thousandths... [.0040=40 tenthousandths]
Not sure what you mean here:
The tech said .030 thirty thousandths.. which [assuming paper thickness of .004" ] is 7.5 paper thicknesses.. not one tenth?
That's about 1/32" which I suppose COULD raise the black plastic piece enough to rub on the rotor like that.. [not saying that's what happened but it is plausible]
Old Aug 11, 2006 | 08:15 PM
  #37
BlackDog's Avatar
I have a question. I read the instructions from MSD, isn't the MSD drive pin indexed too? So, why do we have too remove the cover to ensure the rotor is lined up with the old unit. We don't have to do this with the factory replacement.
Old Aug 11, 2006 | 10:42 PM
  #38
Mtrhds94Z's Avatar
I haven't seen an MSD in person, but would think it was indexed like the stock opti?..
I think they want it done that way to make it idiot proof, tho I can't think why they would want you to take the cap off unneccessarily tho.. that can cause more problems than it cures..
I would be inclined to remove it for a look see and check tightness of screws etc anyway tho..
Actually surprised the unit isn't factory sealed..
Old Aug 11, 2006 | 10:58 PM
  #39
Originally Posted by Mtrhds94Z
soundandthefury:
TEXT PAPERS 25x38
Why am I suddenly starting to feel like I'm trapped in The Twilight Zone's version of "The Mr. Obvious Show?"
Old Aug 12, 2006 | 12:19 AM
  #40
Mtrhds94Z's Avatar
I guess my Q then is do you know the difference between thousandths and ten thousandths of an inch?
.001= 1 thousandth
.0001 =1 tenthousandth...
I just can't understand why you think .030" [30 thousandths] is '10 times smaller than the thickness of one piece of paper' [.0040] when it's the [approx] thickness of 7.5 sheets of paper?
What am I missing here?
Not trying to be critical here.. but I just don't get what you're saying?
.030" is about 1/32" a rather substantial amount..
Old Aug 12, 2006 | 02:46 AM
  #41
MachinistOne's Avatar
I can't believe you guys are confused over measurements of .004" vs .040"...
.004" = 4 thousandths
.040" = 40 thousandths
some examples
a head gasket is typically .039"-.050" thick
binder paper is .003" (measured just now)
dvd is about .050-.060"
Old Aug 12, 2006 | 05:51 AM
  #42
Mtrhds94Z's Avatar
some examples
And .0040 is 40 tenthousandths
'You guys' aren't confused, but I think someone is..
I am politely trying to correct it...
Apparently w/o much success...
Someone else try, I give up...
Old Aug 13, 2006 | 11:12 AM
  #43
NC-LT1's Avatar
I am preparing to install and MSD opti unit also and will be extremely careful after rading this post!
ps..
guys in laymens terms..
how much is 1,000? one thousand..
how much is 10,000? ten thousand
so...
.040 = 40 x .001 = forty one thousands of an inch
.0040= 40 x .0001 = four one thousands of an inch
as such.. at .009, the next number is? thats right .010 when increasing the tenths push to the left towards the decimal.. hence it goes from nine thousands, ten thousands, eleven thousands... until you hit the whole number 1.
don't believe me.. try gapping your plugs to "forty thousands" with a piece of paper and get back to me on how she runs!
Chris
Old Aug 13, 2006 | 08:38 PM
  #44
Thank you. I knew that a piece of paper wasn't 40 thousandths thick. I kind of accidently knocked this thread off topic. I apologize for that.
Old Aug 14, 2006 | 12:47 AM
  #45
IgorT.455/406's Avatar
Well got most of my underhood appart, still have the pass. side manifold to remove, but otherwise I should be ready to start installing my new opti/headers as soon as I get back from holidays next monday. Hopefully the MSD holds up 'cause this would suck doing more then once, lol (although I've done it a few times on my old car).
