View Poll Results: Which oil?
Catrol GTX
19
10.92%
Quaker State
2.87%
havoline
0.57%
valvoline
19
10.92%
penzoil (****ty oil)
3.45%
Mobile 1 synthetic
103
59.20%
Other synthetic
15
8.62%
other...
3.45%
Voters: 174. You may not vote on this poll
Which motor oil?
Old Jun 28, 2003 | 07:48 PM
  #16
1996 | Z28 SS's Avatar
Mobil 1 obviously
Old Jun 28, 2003 | 08:15 PM
  #17
InjectedSS's Avatar
i swear if ANYONE votes on pennzoil ghey ghey ghey
Old Jun 28, 2003 | 08:21 PM
  #18
snakeatinZ's Avatar
mobil1 for life! represent!
Old Jun 29, 2003 | 03:39 AM
  #19
Patman's Avatar
Why? Show me tangible proof that it sucks. Because I've seen pretty good oil analysis results with people using this oil. And it's got one of the better base oils of all the dino oils out there.
If I was running a dino oil, Pennzoil would be one of my top choices.
Old Jun 29, 2003 | 03:53 AM
  #20
tryme96Z's Avatar
Let me clue you in:
Engine:
Mobile One
Tranny:
Mobile One Synthetic ATF
Rear End:
Mobile One Synthetic Gear Lube 75w-90
Misc Lubricating(like bolts and whatnot):
Mobile One Synthetic Universal Grease
As you can tell I don't believe in Mobile One. I have just heard to many great stories about the product to trust it
Old Jun 29, 2003 | 07:52 PM
  #21
SVT Killer LV's Avatar
when I don't use Castrol GTX, I use a fine mix of crisco and cannola...
Old Jun 29, 2003 | 08:59 PM
  #22
lt1form's Avatar
Mobil 1, 15w50 , same stuff thats won Indy many many years.
15w50 has always provided great oil pressure year round, and starts up great even in the cold.
Old Jun 29, 2003 | 09:55 PM
  #23
Chad96SS's Avatar
I agree with LT1coz. Royal Purple isn't the cheapest, but I had Mobil 1 in the engine, tranny and diff that I swapped to RP and I have to shift quicker now. I haven't been to the track to see if it made a difference there, but it definitely revs quicker now. I have heard Mobil keeps cheapening up the formula of Mobil 1 every time they "redesign" it. There was an independent study done a while back that tested all the synthetic formulas and believe it or not Mobil 1 was among the worst performers. I'll see if I can find the link to the site of it's still there.
Old Jun 30, 2003 | 03:51 AM
  #24
Patman's Avatar
You don't honestly believe they use off the shelf $4 Mobil 1 in a $100,000 Indy car engine do you? I heard it happened once or twice, but generally speaking they use custom blends for their oils in those engines.
Old Jun 30, 2003 | 08:45 AM
  #25
darkangel95's Avatar
I use either Mobil 1 5w-30 or Royal Purple 5w-30.
I have RP 75w-90 in the rear end and am about to put RP in the tranny.
Old Jun 30, 2003 | 09:49 AM
  #26
quicksilver97ta's Avatar
Castrol Syntec 5-50w. Its synthetic and the VESCOSITY RANGE says it all really. The 5w provides the flow (especially cold) specified by GM, and the 50w provides the heat/stress shear protection beyond what GM specifies. Synthetics don't use additives to widen the vescosity range like dino oils do.
WIDER IS BETTER.
Old Jun 30, 2003 | 10:35 AM
  #27
CamaroRob97's Avatar
Please find that article!! This is something i think about all the time what really has been proven to be the "best" oil. Im gunna assume its etheir RP od Ams oil. Im not a big fan of Ams oil, not cuz of the price or anything, im sure it does have an advantage over any, "over the counter" oils but i've heard alot bout it leading to premature oil leaks An doing an oil pan an timing cover gaskets in the LT1s atleast isn't really like a project u wana get into unless u have to.
Old Jun 30, 2003 | 11:32 AM
  #28
95 WHITE TRANS's Avatar
mobile 1 all the way. I have heard that rp is in fact mobile 1 with a reddye added.
NICK
Old Jul 3, 2003 | 03:34 AM
  #29
Patman's Avatar
WIDER IS BETTER.
That is one of the worst oils you can use. First of all, it is a dino oil, as Castrol Syntec is not a real synthetic (except for their 0w30 which is labelled made in Germany) Second of all, in order to span such a huge viscosity range, that oil contains TONS of viscosity index improvers. Third, a 50wt oil is too thick for the LT1, and you're going to see higher engine wear as a result. Oil analysis results prove that the LT1 does not need such a thick oil.
Old Jul 3, 2003 | 04:07 AM
  #30
jasonj478's Avatar
Originally posted by Robbie Pendergrass
I use Shaeffer Supreme 5W30 too.
Same Here
