Motor mount question...
Old Dec 19, 2006 | 07:13 PM
wrd1972's Avatar
Going to replace my motor mounts with new rubber ones.
I currently have the mounts out and have noticed that the rubber pieces are incased with plates that are riveted.
My question. When I buy new rubber mounts, do I get just the rubber pieces and have to use my existing plates or do I get a full assembled riveted assembly.
Old Dec 19, 2006 | 07:20 PM
gt_biker13's Avatar
You just get the rubber part. You grind/ drill off the rivits and then put the new rubber pice in there with bolts that come included.
Old Dec 19, 2006 | 08:07 PM
wrd1972's Avatar
Cool, where can I get rubber ones. Even GM parts direct want over $120.
I dont want urathane due to the shaking.
Old Dec 19, 2006 | 08:20 PM
gt_biker13's Avatar
I got mine from http://www.victoryracingengines.com/ , but they were poly. Honestly i didnt notice any shaking or extra vibrations after i installed them.
Old Dec 19, 2006 | 08:22 PM
ss9c1man's Avatar
The shaking isnt that bad. I have a comp 304 with both urethane motor mounts and a urethane trans mount. I really cant tell a difference between the urethane and the old stock rubber.
Old Dec 19, 2006 | 11:43 PM
LT1_383's Avatar
If you buy new GM mounts it comes with the metal surround.
In July of 05 I put ES poly mounts in and ended up taking them out in august of this year. One side shrunk / got dried up and was loose in the clamshell. It was causing the header to hit the steering shaft. Threw new GM rubber mounts in there and fixed the problem. The minimal added vibration was bearable and hardly noticable though. Even with a heads / cam setup it wasn't that bad. I'd stick with the GM rubber mounts, there's very little to gain using poly mounts except a little vibration.
Old Dec 20, 2006 | 07:35 AM
wrd1972's Avatar
Just curious.
What are "ES" motor mounts???
Is there a cheaper source for rubber mounts???
Old Dec 20, 2006 | 08:44 AM
ES = Energy Suspension.
http://www.energysuspension.com/
Old Dec 20, 2006 | 12:26 PM
turbo_Z's Avatar
Go with the ES or Prothane mounts.... you will not be replacing them again. Its my belief headers excelerate the wear on stock rubber mounts so going with them again is a waste. Plus the polyurathane isnt that expensive... something like $50-$60 for the set.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
