View Poll Results: Cam Choices
Voters: 62. You may not vote on this poll
Most Powerful Cam with Regular boltons?
Re: Most Powerful Cam with Regular boltons?
Originally Posted by 1quikZ
just out of curiousty anyone have any problems with using the stock valve springs with the cc306?
Originally Posted by LT1Squirrel
yeah...its not a smart idea whatsoever...
CCA-07-306-8 is that it? costs $245
CCA-07-306-8 $245.95
Estimated Ship Date: Tomorrow
OverviewBrand: Competition Cams
Product Line: Competition Cams Xtreme Energy Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration 050 inch Lift: 230
Exhaust Duration 050 inch Lift: 244
Duration at 050 inch Lift: 230 int./244 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 307
Advertised Duration: 290 int./307 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.540 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Grind Number: LT1 290HR-12
I'm thinking about doing a cam swap for the cc306 myself.
XE230/236 has a smaller lift then the XE227/233. The 230/236 is much more peaky but the 227/233 has a much flatter curve. I was told that it would result in better track times. I dunno, thats what I told (honestly).
I have heard numbers like 360/360 at the wheels with the CC306/GM847 and LT's with untouched heads. Numbers very similar to the 227/233 (But lower) which is a smaller and much more streetable (FROM WHAT I READ!!) cam.
But I have to agree with the custom grind. I heard you just can't go wrong with it, if you explain your situation good enough.
If you wanna match the setup all up correctly, cam and springs etc.... tune the snot out of it and put some Mr Gasket or Impala gaskets on it, the standard bolt ons etc... I think you could see some SICK hp numbers over the 360rwhp range. People used to do that with ported heads that still had stock valves and the standard cams, now they are a good 40hp more than that. With the right setup you could see some silly numbers. Somedays I wish I had a LT1, but then I remeber I could get low 12's just tweaking my LS1.... I know guys sorry to rub it in. I'm really working to get you boys some high 400 and 500rwhp cars so the LS1 guys shut up.
Bret
Bret
