Mobil 1 oil filter for LT1
Old Apr 2, 2008 | 09:53 PM
  #16
dangalla's Avatar
Originally Posted by mdacton
I posted som e pics in advanced tech a few months back of a crushed delco..after I cut it open.....I will never buy another delco for anything. And I use Napa 10w-30 oil...works fine.
really, good to know and news to me
linky for the lazy? me
Old Apr 2, 2008 | 10:11 PM
  #17
mdacton's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=579037
Wix is the way to go or napa gold..only 5 bucks, has metal cage inside bypass etc. Purolator is a good option also.
Ford also has good filters/motorcraft
Old Apr 2, 2008 | 10:17 PM
  #18
dangalla's Avatar
yeah i was just reading that, and i have an endless supply of those, cheap too. i think i might just have to switch to those
Old Apr 2, 2008 | 10:19 PM
  #19
texas94z's Avatar
dude me and a follow board member work for mobil 1. the mobil 1 extended performance filters are JUNK. They leak and crumble to oil pressure. exxon-mobil thinks its cool to slap on the mobil 1 name on a pos filter thats it. everything mobil is junk and overpriced expect for mobil 1 syn oil.
Old Apr 2, 2008 | 10:20 PM
  #20
mdacton's Avatar
to everyone saying how great they are...
Old Apr 3, 2008 | 02:26 AM
  #21
Dave1980's Avatar
I agree I have always heard good things about wix.
Old Apr 3, 2008 | 02:54 AM
  #22
Kaj's Avatar
Kaj
96capricemgr, where might I find this report of your's? Tried doing a search, but didn't comeback with any results. I might be changing oil brands now...
Old Apr 3, 2008 | 02:56 AM
  #23
sbs's Avatar
sbs
Originally Posted by dangalla
what proof do you want, do you think GM would really produce a sub par filter?
Because GM doesn't cut any corners or produce any crappy products?
Originally Posted by 96capricemgr
Been awhile since I really kept up on it but when I did M1 was NOT a great oil for the LT1, now if you had say a turbo VW it was awesome, but NOT a smallblock Chevy of any generation.
Which is why more than 100,000 LT1/4s came from the factory with M1 and a "Use M1 only" label...
Old Apr 3, 2008 | 03:27 AM
  #24
Kaj's Avatar
Kaj
I don't understand this great oil debate. I've been told to only run M1 5w-30 or 10w-30 for aslong as I've owned my z28 (12years). I understand how marketing etc play a role in everything blah blah blah. With that aside I don't see how an oil analysis would give you a better oil than all the rest, because there are too many variables to account for....i.e dirt roads, weather, operation of vehicle at wot non-stop etc.
I live in a place where it's not uncommon to see -30 degrees in winter and 101 degrees in summer. I've never had a problem with oil pressure, leaks, broken internal parts, metal shavings....nothing. Mobil 1 5w-30 has been in my car exclusively for 12 years strong. Changed every 3000 miles exactly, and now have 63,002 miles after I changed oil yesterday. Car is alive and full of power as it has ever been, and has been far from being pampered....*shrugs* so wtf!
Now, the M1 Filter is a different matter..... I've never used one before. Only WIX or K&N
Old Apr 3, 2008 | 07:37 AM
  #25
PoorMan's Avatar
The longer Mobil filter is listed for the H2 Hummer in the book.
JD
Old Apr 3, 2008 | 07:40 AM
  #26
maverickmk's Avatar
I've been told that the Fram filters collapse as well - as for changing M1 every 3k miles I think that is a waste of money - you can go a lot longer between changes with a synth oil
Old Apr 3, 2008 | 08:33 AM
  #27
mdacton's Avatar
bob is the oil guy site list the best filters.....guess whats #1?
There is plenty of oil reports there.....I wouldn't waste money on M1....wouldn't put it in my lawn mower if you gave it to me.
Old Apr 3, 2008 | 10:28 AM
  #28
cvccbum's Avatar
there was a post on here awhile back saying it actually harms your engine more if you change it that early. they said it was better to keep it for many miles over recommended, but to change the filter in those intervals.
i still change mine at least every 3-5k though.
Old Apr 3, 2008 | 10:47 AM
  #29
dangalla's Avatar
every time you change your oil you encounter a "dry start" when it takes a few seconds for the pump to prime and then fill the filter and oil galleys.
Old Apr 3, 2008 | 01:08 PM
  #30
speed_demon24's Avatar
Don't believe everything you read online.
