Oil filter bypass filter selection
Old Feb 8, 2008 | 10:21 PM
mdacton's Avatar
I have one of the billet block offs for the bypass for SBC.
What filter should I be using? I made the mistake of using a Delco 1218
Do I need the bypass and drainback or what?
Anyone have a part number for a Wix racing? or what brand is best? moroso?
Old Feb 9, 2008 | 12:43 AM
Stephen 87 IROC's Avatar
I use a System 1 filter so I never have to buy another filter. I take it off and clean it for inspection a few times a season. If I had to use a paper filter, I would only use a Wix or and other brand that uses Wix and puts their own name on it.
All the bypass does is allows the oil to bypass the filter if the filter gets plugged. If you go that long between changing filters, you have more problems than putting dirty oil through the engine.
The bypass is a pressure differential valve. When there's equal pressure on both sides, it stays closed and the oil goes through the filter. When the filter becomes plugged, there's a higher pressure on the inlet side than the outlet side and the oil is allowed to flow through the bypass.
Removing the bypass means you're trying to force the oil through the filter all the time even if it becomes plugged which means you could starve the engine of oil and/or blow the filter. A race engine that frequently removes the filter to be cut open for inspection can run with the bypass plugged.
Old Feb 9, 2008 | 08:04 AM
mdacton's Avatar
Well I change the filter several time, but I read that at cold temps its hard for the cold oil to be forced through the filter, thats where to bypass comes in.
I was just wondering
Old Feb 9, 2008 | 10:54 AM
mdacton's Avatar
Well I cut the delco filter open.....it just crushed that.
This is exactly how I pulled it out. The inside plasic cage is crushed, It had to be from cold start. Its only been on there a week...no miles on it. Started it 2 or 3 times and messed with the tune
Old Feb 9, 2008 | 12:14 PM
mdacton's Avatar
well I put the wix racing on it and ran it a little bit. I'm about to cut that open and take them both to someone and get checked. I think its starting to eat a bearing...It sure looks like it to me but I'm not 100%.
I started it yesterday and had low oil pressure, cut it off and checked everything. tried again and it was fine....that must have been when it busted the filter. It was about 60 outside too. So I don't have a clue what the deal is here.....or maybe I'm making a bit deal out of nothing
Old Feb 9, 2008 | 12:17 PM
Take a chuck of filter material and squish it in a vise to get all the oil out. Then open the material up to inspect for any metal.
Old Feb 9, 2008 | 11:31 PM
mdacton's Avatar
We did, I changed the oil and tried another WIX filter too......everything is good. I'm just paranoid........the delco filters area POS, and a definate NO without the bypass. Glad I cought it
It crushed the little inner plastic cage on the delco.....but it looks like all the pieces were still in it so no big deal.
Old Feb 10, 2008 | 05:43 AM
FASTFATBOY's Avatar
I use a K&N HP 3002, try that one.It is the longer version of the 2002.
David
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
