Missfire help...
Old Apr 14, 2007 | 02:49 PM
z28-06's Avatar
Missfire help...
Been trying to track down this problem since I bought it 1.5 years ago.
Description- Missfire anywhere from 4500-5700 rpm and does it about 50% of the time in any gear.
-New Optispark
-wires have 10k on them
-coil is a msd blaster
-Not sure on plugs-bought some ngk tr-55 not put in yet
-new fuel filter
-good fuel pressure at idle
*What else should I check? Any ideas on whats causing this? Any help would be great!
-andy
Old Apr 14, 2007 | 05:00 PM
transAMdriv3r's Avatar
Try cleaning your mass air flow sensor with some alcohol. It may be dirty and causing your misfire.
Old Apr 16, 2007 | 09:33 PM
z28-06's Avatar
thanks, any other thoughts?
Old Apr 17, 2007 | 11:28 AM
could be fuel filter also
Old Apr 17, 2007 | 01:35 PM
z28-06's Avatar
Just changed fuel filter and it has good fuel pressure at idle.
Old Apr 17, 2007 | 02:10 PM
TMDZ28's Avatar
is it only happens when hot?
Old Apr 17, 2007 | 05:24 PM
z28-06's Avatar
actually now that I think about it... yes. It seems right after i pull it out and not quite up to operating temps there is no missfire. Ill take it out tonight and test this again. Thanks
Old Apr 17, 2007 | 07:57 PM
z28-06's Avatar
I just took it out and while it was cold it did not missfire once but when it got hot I would say half the time it missfired.
Old Apr 17, 2007 | 09:46 PM
onebad636's Avatar
I just put a new optispark on mine tonight and now it missfires really bad. From about 3500 on up. It seems worse when I hook up my Mallory ignition but even without it it still does it.
Old Apr 18, 2007 | 09:17 PM
doug1105's Avatar
optispark wire harness cooked?
Old Apr 18, 2007 | 09:59 PM
JWS6's Avatar
have your ignition control module tested at autozone?
Old Apr 18, 2007 | 10:21 PM
bombebomb's Avatar
Did you check your air filter, I forgot to change mine and it started missing randomly at high rpms lol
EDIT: since you have CAI it would be
did you clean your air filter.
Dylan Latshaw
Mar 21, 2015 09:48 AM
NEOS97SS
Jul 10, 2003 07:59 PM
mastrdrver
May 15, 2003 03:52 PM
Green G0blin
Apr 16, 2003 12:18 PM
Chris 96 WS6
Apr 16, 2003 07:54 AM
