milling heads/intake questions
Old Jul 28, 2003 | 12:41 AM
JJJ93z's Avatar
i have a guy that can do all the milling for free, i was just curious what specs did you guys mill to? does anyone know what the specs for an LT4 intake and heads are? the donor motor is a 93, so its the same as the year of my current car, if i milled it out to the lt4 specs and did a lt4 hot cam how much rwhp would i have, what else would i need to get (besides gaskets) in order for the motor to run. also how much would it cost to do a 383 minus the cost of milling ? thats a lot of questions but if i can get a couple answered i will be happy! thanks for your time
Old Jul 28, 2003 | 12:55 AM
96z's Avatar
96z
What would be your purpose for milling? More compression? Just to clean them up? Otherwise leave them alone.
Also do a search, you will read for hours.
Old Jul 28, 2003 | 07:06 PM
JJJ93z's Avatar
more compression, do you know of any good web pages with info , b/c searching on here sometimes isnt the best option , if you have any sites on milling for more compresssion or just general milling that would be great b/c i would love to learn more thanks
Old Jul 28, 2003 | 07:16 PM
mineralwater's Avatar
a cheaper way of getting some compression would be to just get some thinner head gaskets. impala gaskets have a compresed height of .029" as opposed to the stock .049" too. I'm not sure how much it'll raise compresion - probably not much, maybe .2-.4 points? does anybody know?
It'll at least improve quench, whatever that means :P
Old Jul 28, 2003 | 07:25 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
sometimes you need more, as in my case.
you want to get upto ~12:1 compression with thin headgaskets
Old Jul 28, 2003 | 09:19 PM
thewinner's Avatar
ALWAYS mill aluminum heads.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
