milling heads/intake questions
i have a guy that can do all the milling for free, i was just curious what specs did you guys mill to? does anyone know what the specs for an LT4 intake and heads are? the donor motor is a 93, so its the same as the year of my current car, if i milled it out to the lt4 specs and did a lt4 hot cam how much rwhp would i have, what else would i need to get (besides gaskets) in order for the motor to run. also how much would it cost to do a 383 minus the cost of milling ? thats a lot of questions but if i can get a couple answered i will be happy! thanks for your time
Originally posted by 96z
What would be your purpose for milling? More compression? Just to clean them up? Otherwise leave them alone.
Also do a search, you will read for hours.
a cheaper way of getting some compression would be to just get some thinner head gaskets. impala gaskets have a compresed height of .029" as opposed to the stock .049" too. I'm not sure how much it'll raise compresion - probably not much, maybe .2-.4 points? does anybody know?
It'll at least improve quench, whatever that means :P
you want to get upto ~12:1 compression with thin headgaskets
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
