Melling oil pump users may want to look at this
Old Apr 30, 2007 | 01:58 PM
  #61
jasonisdn's Avatar
seawolf please remove the summit link you have posted. that pump number will not work on a LT1. trust me its setting in front of me now and it's no where near the correct style of pump.
Originally Posted by seawolf06
http://store.summitracing.com/partde...5&autoview=sku
That's the high pressure Select pump. I think you could get the white spring for less than $25 though.
They have two different HV pumps as well. One is 10% more and one is 25% more. The standard M55HV is 25% more volume. What do you think about running the 10% more volume with a stock pan? Could get that and install the white spring for higher pressure. It comes with the hardened driveshaft and anti-cavitation capable. It does note that the anti-cavitation does slightly reduce oil pressure at idle.
Old Apr 30, 2007 | 02:16 PM
  #62
foggedz's Avatar
Originally Posted by Colin91Z
Melling lists several bolt-on pickup screens for their select pumps (10554, 10552, 10550, etc...)
I'm not sure which to order....
They list part # 12557 for 7" deep pans, part # 12558 for 7 1/2" deep pans, and part # 12559 for 8" deep pans. Which is the best match for a stock pan?
Anyone know?
Just to let everyone know the 10554 does not have a bolt on pickup. The pickup will need to be welded to the pump.
Old Apr 30, 2007 | 02:25 PM
  #63
Colin91Z's Avatar
Hmmm...no kidding? I thought all of the select series would accept a bolt-on or a press-fit screen...thats what summit's catalog says about them anyways
Thanks for the heads up
Old Apr 30, 2007 | 03:15 PM
  #64
foggedz's Avatar
It is a press fit, but the pump itself is not drilled and taped for a bolt on pickup. If you look on the mellings site, they have a chart showing what "select" pumps accept a bolt on pickup. The 10554 does not have it. I just bought a standard 3/4in pickup tube for a stock depth pan. Pressed it in an had it welded in. Even with the pickup pressed in it can still shift inside the pump with a little force.
Old Apr 30, 2007 | 03:28 PM
  #65
Colin91Z's Avatar
Cool, thanks for the info
Old Apr 30, 2007 | 04:19 PM
  #66
12SCNDZ's Avatar
Anyone using this combo, from Summit? It uses the Melling M55A pump with the pick-up welded.
Frank
CPT
Old Apr 30, 2007 | 04:27 PM
  #67
Colin91Z's Avatar
Frank
CPT
Just so ya know, the M55A only has a 5/8" pickup tube...I just sold one last week
Old Apr 30, 2007 | 04:57 PM
  #68
jasonisdn's Avatar
if people are using the 10552. anyone see any issues with using the 10552c
any issues at all? it will be used in a canton road race pan.
Old Apr 30, 2007 | 05:15 PM
  #69
bdc95ta's Avatar
Jason contact canton, they'll give you there recomendation, that's what I did w/ my Stef's.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Sep 8, 2002 01:47 PM
