Melling oil pump users may want to look at this
Old Jan 15, 2007 | 01:47 AM
  #16
JAG05's Avatar
Originally Posted by seawolf06
http://store.summitracing.com/partde...5&autoview=sku
That's the high pressure Select pump. I think you could get the white spring for less than $25 though.
They have two different HV pumps as well. One is 10% more and one is 25% more. The standard M55HV is 25% more volume. What do you think about running the 10% more volume with a stock pan? Could get that and install the white spring for higher pressure. It comes with the hardened driveshaft and anti-cavitation capable. It does note that the anti-cavitation does slightly reduce oil pressure at idle.
Will running a 25% more pump on a stock pan cause problems?
Old Jan 15, 2007 | 02:17 AM
  #17
seawolf06's Avatar
Yes, the standard HV pump has caused oil starvation with stock pans in many cases.
Old Jan 15, 2007 | 02:21 AM
  #18
JAG05's Avatar
So will the stock pump running at the factory oil pressure be ok to build say a 355 or a 383 with a mild cam? Or would you need the HV [ump and a different pan?
Old Jan 15, 2007 | 02:47 AM
  #19
seawolf06's Avatar
Depends on the RPM you want to turn I think.
Old Jan 15, 2007 | 07:28 AM
  #20
wrd1972's Avatar
So how about this combo.
The Melling 10553 standard flow oil pump with the GM white spring in a 355 reving to 6.5K RPM?
That will bump pressure up just a bit without out pan dry issues I hope.
Old Apr 9, 2007 | 12:00 PM
  #21
blown383's Avatar
ttt for future reference.
-B
Old Apr 10, 2007 | 03:28 PM
  #22
bdc95ta's Avatar
I have a HV pump which looks different from the standard comparison pics; can anyone verify if I have the old or new design?
thanks,
-b
Old Apr 10, 2007 | 04:18 PM
  #23
blown383's Avatar
Looks like you have the crappy new casting.
-B
Old Apr 10, 2007 | 07:26 PM
  #24
tnmotown's Avatar
im with you bdc95ta, i have the same M155HV pump in my room to be installed.
So that one the the old design then?
Old Apr 10, 2007 | 07:33 PM
  #25
sam pace's Avatar
nope that one is the new and they are very cheap.
the select pumps are like night and day.compared to the new casting
Old Apr 10, 2007 | 08:13 PM
  #26
blown383's Avatar
I have the same pump and was wondering which Melling Select pump do we use with a Canton pan and pick up? My car is a..... you guessed it.... Blown383
-B
Old Apr 10, 2007 | 08:20 PM
  #27
sam pace's Avatar
http://store.summitracing.com/egnsea...115+4294908216
Pick your poison
I have the 10552 with the white spring.
Old Apr 10, 2007 | 11:57 PM
  #28
jclark311's Avatar
Thanks for the info, doing my motor right now!
Old Apr 11, 2007 | 11:36 AM
  #29
buzz12586's Avatar
So if I currently have a M155HV pump waiting to go in my motor what should I switch it out for? Is the 10552 the best alternative???
Will a 10% increase over stock be ok or will it drain the pan as well??
Old Apr 11, 2007 | 01:28 PM
  #30
mzgp5x's Avatar
When I put my 383 together, I noticed the Melling HV stud mount hole was not drilled @ Rt angle to the block mount face. I releaved the hole a bit so the stud would not result in additional casting stress when torqued. Melling quality control sucks. So far, I still have 40+ psi oil press @ idle. I hope it does not break. Also used a Canton road pan.
