MAF reading 0 on Scanmaster
Old Apr 22, 2004 | 06:55 AM
Amped96's Avatar
Question MAF reading 0 on Scanmaster
Well, I just got my scanmaster installed yesterday and when I drove the car and started looking through all the displays I noticed the MAF is always reading 00. I checked and it is plugged in and the car seems to be running fine.
Only problem I have noticed lately is when the car is cold, I have a part throttle, low RPM miss sometimes. This just started happening a day or two ago. It goes away once the car is warmed up though. As for the MAF...could my car be running perfectly fine if the MAF really is always seeing 00?? My MAF is stock except I took the screen out.
Old Apr 22, 2004 | 07:38 AM
95 Silver TA's Avatar
Some thing is definetly wrong it should be reading numbers and they should increase as your rpms increase. Are you getting any SES light or codes?
Did you try to disconnect it, clean it and plug it back in. Also you may want to find another person with an F-Body and swap out mafs and see if your readings get better.
Good Luck.
Claude
Old Apr 22, 2004 | 10:06 AM
HBHRacing's Avatar
it's posable it's bad. use this link to test the circuts to the MAF http://mainstreamtopics.com/forum/in...?showtopic=207
Old Apr 23, 2004 | 07:37 AM
Amped96's Avatar
Thanks guys. I guess I am going to try and test all the connections with a multimeter this weekend. Can I test the sensor itself with a meter?? I have a helms manual and a haynes manual, but haven't checked either yet for tips.
Why would my car seem to be running so well with the MAF not giving a reading?
Old Apr 23, 2004 | 09:27 AM
ping0317's Avatar
where did you get your scanmaster... what does it actually do?
Old Apr 23, 2004 | 09:49 AM
OBE1 95Z28's Avatar
If your MAF fails or is not plugged in, your car defaults to speed density mode (selects air/fuel curves and timing based on throttle position and the MAP sensor). Your scansmaster will show you if you're throwing and codes.
Old Apr 23, 2004 | 09:56 AM
scoobysnax83's Avatar
If you were having a malfunction like that on the MAF end, then you would be getting an SES light for sure as well as fans that never shut off.
More than likely the last owner reverted to speed density and left it in there as a spacer or to make it look stock. It is possible however that it is defective and that it was programmed out to save money.
Old Apr 24, 2004 | 06:13 AM
Amped96's Avatar
Well, the scanmaster will not read trouble codes on my car, becaues it is OBDII. It will do all functions except read trouble codes on the 96-97 cars. It will only read the trouble codes on the OBDI cars.
I do have an SES light, but I was just assuming that it was from all the emissions stuff that I have removed. I have autotap, but I keep getting an error with it every time I try to get the trouble codes. I will be contacting autotap soon I guess.
First thing this morning, I think I am going to check some fuses. I have had a few other wacky things happen on my car recently (reverse lock out solenoid seems stuck...car is a major pain to get into reverse).
Old Apr 24, 2004 | 07:04 AM
My reverse is a biotch, too. Just requires a whole lot of extra effort, unless of course I'm going from a 4th to 5th, THEN of course it slips right into Reverse.
I should probably replace that.
Old Apr 30, 2004 | 02:56 PM
Amped96's Avatar
Well, was checking connections with the multimeter and noticed I was getting the 5V reference signal to the MAF, but no 12V hot. Found out the fuse under the hood labeled "ENG SENSOR" was blown. This was also the reason my reverse lockout solenoid was stuck. Amazing what a fuse can do. My MAF now works and I can put the car in reverse easily.
Old Apr 30, 2004 | 03:25 PM
It always helps to fix stuff, instead of ignoring the lights.
Old Apr 30, 2004 | 03:30 PM
Frans96SS's Avatar
dude that is so wierd im just reading on here being bored my maf was readng 0 also so i clicked on this read it and remember when i had my 6 speed reverse was hard to get into then when u said that fuse was blown sure enough went and looked at mine and it was blown thank u very much ahah
Old May 1, 2004 | 05:15 AM
Amped96's Avatar
I have gotten use to seeing the SES light due to !AIR, !EGR, !cats, so I don't know when a new code pops up. Guess I need to get all that stuff programmed out so I can have a functioning light again.
Peytons'z
May 6, 2021 09:25 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
R@mpage
Apr 20, 2015 10:02 AM
Rich_z28
Sep 13, 2002 03:35 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
