MAF not working
Old Jun 4, 2004 | 08:39 PM
jer4251's Avatar
MAF not working
I have a slight problem that i need help fixing. My MAF isn't working properly. I took the car down to autozone and they came up with 2 codes, p0100 and p0403. he said one was the egr and the other was the maf. that was with my stock computer. after the obd1 w/tuning i still have the maf code. has anyone had it before? do i need a new maf sensor or do i have a wiring problem somewhere? i just need it fixed, it's killin my hp and gas milage. thanks
Old Jun 5, 2004 | 11:49 AM
Check the pink wire in the MAF harness connector for +12V with the key on. Seems like in the 97's that wire is a major problem.
Old Jun 5, 2004 | 12:35 PM
Josh-'04 GTO's Avatar
Have you ever cleaned the MAF element? If not, you could have a bunch of grime on it, causing incorrect readings. Or you could have dinged up the sensor element putting on your new MAF ends...
Old Jun 6, 2004 | 01:25 AM
jer4251's Avatar
i have the tool to test the wire but i'm not sure how to use it. should i swap out maf sensors to see if another one fixes the problem? i'd have to fine some1 with one near me. most of the guys i know have LS1's
if the wire comes back withlow voltage, how do i fix it?
thanks
DirtyDaveW
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
