LTCC wiring question
Old Jun 24, 2006 | 07:50 PM
Gripenfelter's Avatar
Which pink wire with the black tracer do you use for power?
The one that plugs into the front of the coil or the one out of the 4 pin connector that plugs into the ign module?
I used the white wire from the ign module harness for the white wire on the LTCC.
I upgraded to a 25 amp fuse but have no fire.
I connected the pinks to the pink/black tracer on the 4 pin ign module.
Old Jun 25, 2006 | 09:06 AM
Re: LTCC wiring question
ttt
Old Jun 25, 2006 | 10:14 AM
Loadre's Avatar
Replied to your PM. You use the one coming off the coil.
Old Jun 25, 2006 | 04:43 PM
For 93s its the solid pink wire as it turns out.
But now my rpm guage won't work.
Any ideas?
Old Jun 25, 2006 | 04:57 PM
BIG SHAFE's Avatar
Any ideas?
But it runs?
When you connected the LTCC inline with the opti did you check for debris/junk on the terminals? I looked when I did mine but I didn't have anything on it.
Old Jun 25, 2006 | 05:00 PM
It runs.
Didn't check for debris. Does the signal come from the opti then?
I thought it might be by the coil.
Old Jun 25, 2006 | 06:27 PM
BIG SHAFE's Avatar
It runs.
I'm almost 100% the signal comes from the opti, then the computer processes it and sends a signal to the module which in turn signals the coil to fire. Someone else may know for sure.
Old Jun 25, 2006 | 06:42 PM
Does the rpm guage get its signal from the coil or from the opti?
Old Jun 25, 2006 | 07:17 PM
Loadre's Avatar
The tach in the cluster gets its signal straight from the PCM. It's the same type signal you tapped into from the white wire off the ICM.
Old Jun 25, 2006 | 07:53 PM
Thats weird. I wonder why the guage is dead. The rest of them work. Just not rpm. I hooked up a scan tool and I can see the rpm. But the dash one is dead.
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
