lt1's
i wanna put a lt1 in a 95 3.4 and around here the camaro lt1's are hard to find but the roadmaster and caprices are a dime a dozen. and no i dont wanna sell my car for a z! i pretty much want the motor so i can rebuild it and put it in.
be cautious when looking for an Lt1 cause the 4.3L v8 looks EXACTLY like an Lt1.
the B-body Lt1s have cast iron heads,smaller MAF,cam is designed for the low end grunt and the pcm has a different tune.
Some info on the LT1, showing a few of the differences on the various cars it was installed in, the caution on the 4.3L L99, cam differences, etc.
http://www.automotiverebuilder.com/ar/ar99928.htm
Are you pulling the LT1 out of your F-Body, and replacing it with a B-Body LT1? If so, give us a clue... what year is your car? That will tell you whether you already have an OBD-II PCM of not.
Why not add a "signature" with basic info about your car.... model, year, engine, tranny and any major mods? That way people can answer your questions without guessing.
check the vin of the car if its a p its the 5.7 all lt1;s got a vin p as far as diff heads and cam are diff b/body also has 2 knock sensors as opposed to f/bodys 1all b/bodys had vented opti comp has a diff tune in it easily changed...........as far as motor and comp is concerned
oldschool
Feb 9, 2016 09:21 PM
