lt1's
Old Dec 12, 2007 | 07:50 PM
yourmom's Avatar
lt1's
so what is the difference between the camaro lt1 and the caprice lt1 besides the power rating. what computer would i need for the swap.
Old Dec 12, 2007 | 07:52 PM
'94 Bad A Z28's Avatar
Not too sure but the heads are different, besides that I am not sure. But what swap are you talking about?
Old Dec 12, 2007 | 07:53 PM
dangalla's Avatar
the search function is your friend
Old Dec 12, 2007 | 09:27 PM
yourmom's Avatar
i wanna put a lt1 in a 95 3.4 and around here the camaro lt1's are hard to find but the roadmaster and caprices are a dime a dozen. and no i dont wanna sell my car for a z! i pretty much want the motor so i can rebuild it and put it in.
Old Dec 13, 2007 | 09:10 AM
96m6lt1's Avatar
be cautious when looking for an Lt1 cause the 4.3L v8 looks EXACTLY like an Lt1.
the B-body Lt1s have cast iron heads,smaller MAF,cam is designed for the low end grunt and the pcm has a different tune.
Old Dec 13, 2007 | 09:45 AM
Some info on the LT1, showing a few of the differences on the various cars it was installed in, the caution on the 4.3L L99, cam differences, etc.
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Dec 13, 2007 | 10:17 PM
yourmom's Avatar
its definentaly the 350 vin"p" so just some tips on this paticular swap.
Old Dec 13, 2007 | 11:06 PM
Are you pulling the LT1 out of your F-Body, and replacing it with a B-Body LT1? If so, give us a clue... what year is your car? That will tell you whether you already have an OBD-II PCM of not.
Why not add a "signature" with basic info about your car.... model, year, engine, tranny and any major mods? That way people can answer your questions without guessing.
Old Dec 14, 2007 | 02:52 PM
yourmom's Avatar
not sure how to do the signature. its a 95 3.4 camaro i am gonna build a lt1 b body motor
Old Dec 14, 2007 | 05:39 PM
93v8clone's Avatar
check the vin of the car if its a p its the 5.7 all lt1;s got a vin p as far as diff heads and cam are diff b/body also has 2 knock sensors as opposed to f/bodys 1all b/bodys had vented opti comp has a diff tune in it easily changed...........as far as motor and comp is concerned
Old Dec 14, 2007 | 06:30 PM
n2ceptor's Avatar
Go to top of page; USER CP ............
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
