lt1 power steering and alt only
Old Dec 11, 2007 | 11:12 AM
White Lightning's Avatar
does anyone know any place that makes a bracket or something to use just the alt and power steering, even if using a different pump, i found zoops makes one for one or the other but not both, anyone else using this setup
Old Dec 11, 2007 | 05:32 PM
Are you asking what you do when you remove the A/C compressor, and want to continue to run the PS pump and alternator? If so, you could use the 1LE A/C delete bracket.
If you are considering relocating your alternator to where the A/C compressor used to be, there is a thread here that shows how someone did it, using an idler pulley where the alternator used to be. A "search" might turn up the thread. I'll see if I can find it.
Old Dec 11, 2007 | 08:14 PM
thesoundandthefury's Avatar
This thread has some good ideas:
https://www.camaroz28.com/forums/sho...24#post4649824
Old Dec 13, 2007 | 05:25 PM
anyone else?
Old Dec 13, 2007 | 07:39 PM
Mockup of my engine project. This is the "Chevelle Style" mid-mount alternator/low mount P/S bracket kit from Street & Performance. It is currently the only "bolt-on" Alt & P/S kit available for the LT1 that does away with the stock accessory bracket. Anything else will have to either be mixed & matched or custom fabbed.
Old Dec 14, 2007 | 08:15 AM
i found that last nite, do u really have to use a vette balancer? and its a lil pricey, but o well, if they would make a plain kit without the bling i would be all over it,depending on the balancer
Old Dec 14, 2007 | 08:20 AM
Old Dec 14, 2007 | 09:46 AM
jpack24's Avatar
Link please, tried finding it on their site but to no avail. Thanks.
Old Dec 15, 2007 | 03:31 AM
Non-sponsor link. PM sent.
HectorM52
Jul 30, 2017 11:46 AM
Airplanedoc
Feb 1, 2015 07:14 PM
Gtpguy
Jan 26, 2015 04:50 PM
ro2207
Dec 4, 2014 06:18 PM
XtremeLt1
Sep 13, 2002 08:50 PM
