LT1 running rough
Old May 19, 2004 | 10:32 PM
tomt1986's Avatar
LT1 running rough
hey guys i have been having a problem with my 94 lt1. It has been running very rough when it warms up. when the car runs at 180 degrees it is very choppy and wont accelerate. Sounds like alot of backfiring. I Changed my opti,plugs,coil. and theres no difference. It must be a fuel problem. When i pulled my plugs 1,3,5,7 were all clean and looked normal. 2,4,6,8 were covered in black soot? (looked like they werent firing) anyone have any idea's?
Tom
Old May 19, 2004 | 10:39 PM
FastWhiteTA's Avatar
A few things...you might have the plug wires on the wrong cylinders, or, you might have the opti installed wrong. There's a dowel pin coming off the cam you need to make sure you line up correctly to the opti. When you install the opti, it should have made a clean solid connection when you push it into the timing cover. I'd check the wires, and rule out other obvious things before you go in and reintall the opti, I know it's a PAIN.
Old May 19, 2004 | 10:40 PM
DonHood's Avatar
O2 sensor on the passenger side could be reading wrong, and causing that cylinder bank to run really rich. It's the same exact thing that's happening to me right now.
Old May 19, 2004 | 10:50 PM
Donny O's Avatar
i second that motion.....exactly what I was thinking. that is about the only thing that really seperates one side from the other!!
Old May 19, 2004 | 10:57 PM
scoobysnax83's Avatar
I second the second....
Old May 19, 2004 | 11:10 PM
tomt1986's Avatar
Thanks i will order one up tomorrow.
Tom
Old May 19, 2004 | 11:12 PM
Donny O's Avatar
Tom
problaby be a good idea to replace both of them together. i'm sure there is a good logical reasonf ro that but i jstu cant think of it right now!!
problaby something like they are the same age and if one went bad the other one might not be working 100% either!!
Old May 19, 2004 | 11:28 PM
Yea, definitely a good idea. I would never replace only one.
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
cmdeshon
Dec 12, 2014 10:51 PM
Scottylt1
Dec 4, 2014 12:31 PM
